Whicht cold air intake Filter would you prefer?
darkriff
I know this might be asked many times before. But i've heard there is some issues with the prozen filter and the check engine light
K&N Filters 77-2574KS 2007-10 Ford Edge 3.5L Cold Air Intake 11 HP Gain
http://bit.ly/IRze33
Or this one
2012 Ford Edge 3.5V6 Cold Air Intake + K&N filter NEW
http://bit.ly/IRzpv8
Thanks
The second
I guess he is neither because both filters will let quite a bit of dirt into the engine. If you are going to get one of those intake systems change the filter on it for an AMSOIL filter, it may let in a little less air but not by much but will also not let in any dirt like those filters.
plus both intakes that you show both use the same k&n filter so there really isn't a difference. you simply showed 2 different intakes for the different model years. so obviously you'd buy the one that was for your model year and swap out the filter as SamIAm suggested..
