rapi99 Posted May 9, 2012 Report Share Posted May 9, 2012 Hello, i have a 2008 MKX. Is it possible to shutting down the rear vents if i use the AC in the front? I don´t want to use them in the back when my kid is with me. All he get are cold legs. Ralf Quote Link to comment Share on other sites More sharing options...
Eatinitup Posted May 10, 2012 Report Share Posted May 10, 2012 Unfortunately, there isn't a switch on the vent itself to turn them off. You would literally have to come up with something to close them. Either taping over them or actually mocking some sort of a concoction to actually stop the air flow. I don't understand why they don't have the butterfly valve like th front vents, but then again.. I am not the design engineer. I would to be able to turn them off in the daytime especially when its hot in the vehicle. More airflow to the front vent's would be better, especially when nobody is sitting in the rear! Quote Link to comment Share on other sites More sharing options...
rapi99 Posted May 16, 2012 Author Report Share Posted May 16, 2012 Thanks for reply... good to know that i am not stupid to turn them off... ;-) Quote Link to comment Share on other sites More sharing options...
JOEHIO Posted May 18, 2012 Report Share Posted May 18, 2012 True, you cannot completely turn the rear vents off, but if you slide the lever to the leftmost on the left, and right on the right, it does restrict the amoount of air that comes through the vents. Give it a try. Joe Quote Link to comment Share on other sites More sharing options...
