wannabang Posted May 24, 2013 Report Share Posted May 24, 2013 My SEL had a sub-out. I have the first gen, though... and replaced my HU Quote Link to comment Share on other sites More sharing options...
shiro_se Posted May 26, 2013 Report Share Posted May 26, 2013 On 5/16/2013 at 5:11 AM, menasci said: Is there a difference between the 08-10 and the 11-13 sub enclosure? I just put a '11 MKX sub in my wife's '09 Edge, so I would say there is no difference. Hers has no sub, but I was able to easily detach the cubby from the back of the trim panel by cutting off the melted over pins on the back of the 'bucket'. Does anyone know where to get a decent looking grille to cover the hole? I like the idea of it looking OEM. Also, I bought a harness adapter off Ebay and it came with a line level converter. I found a connector behind the front passenger kick panel that this connector fits, but when the connector is separated, the stereo operates normally, so I have my doubts whether this is the right connector. Any thoughts? Leigh Quote Link to comment Share on other sites More sharing options...
shiro_se Posted May 27, 2013 Report Share Posted May 27, 2013 Well, I got it done, without using the connector. The speaker connector is there behind the passenger kick panel, but it's forward of the connector that the Ebay seller supplied. I found the wire colours in another post, so I soldered the line level converter to the RF and RR speakers to maintain some sort of Fade control. The Remote signal wire is also there, just a single wire in its own conector, just above the other two large connectors. I had a lot of extra length on the RCA cable so I was able to tuck the converter away at the top of the kick panel and all I have to remove to get to it is the fan cover to get to it. Just two fir tree fasteners hold that in place, so easy adjustments to the sub level can be made. I used a Kenwood 250W amp screwed directly to the back of the OEM sub and powered it via a 10ga wire directly to the battery side of the 100A megafuse in the engine bay fusebox. Thank you Ford for not requiring dash removal to do simple add-ons to the stereo system in the Edge! Quote Link to comment Share on other sites More sharing options...
ravishingrocket Posted May 31, 2013 Report Share Posted May 31, 2013 On 5/24/2013 at 12:16 PM, Dingo said: I don't know. If not, tap the front speakers. Did you tap the power wire on the factory HU for the remote wire on the lc2i? Quote Link to comment Share on other sites More sharing options...
Dingo Posted May 31, 2013 Report Share Posted May 31, 2013 No. Quote Link to comment Share on other sites More sharing options...
ravishingrocket Posted May 31, 2013 Report Share Posted May 31, 2013 On 5/31/2013 at 1:58 AM, Dingo said: No. Where did you tap? I was thinking HU power wire becuz I sometimes sit and listen to radio after I turn the car off Quote Link to comment Share on other sites More sharing options...
Dingo Posted May 31, 2013 Report Share Posted May 31, 2013 I didn't tap anything. Quote Link to comment Share on other sites More sharing options...
ravishingrocket Posted May 31, 2013 Report Share Posted May 31, 2013 On 5/31/2013 at 3:17 PM, Dingo said: I didn't tap anything. Straight to the battery? Quote Link to comment Share on other sites More sharing options...
Dingo Posted May 31, 2013 Report Share Posted May 31, 2013 Look up the "GTO" feature in the manual. Quote Link to comment Share on other sites More sharing options...
wannabang Posted June 1, 2013 Report Share Posted June 1, 2013 Some amps have a sensor built in to sense a radio signal and trigger the amp to turn on. Others do not. Those that don't need to "tap" the amps remote wire into the HU's remote wire. ..is that what you were wondering? Quote Link to comment Share on other sites More sharing options...
ravishingrocket Posted June 1, 2013 Report Share Posted June 1, 2013 On 6/1/2013 at 1:14 AM, wannabang said: Some amps have a sensor built in to sense a radio signal and trigger the amp to turn on. Others do not. Those that don't need to "tap" the amps remote wire into the HU's remote wire. ..is that what you were wondering? My amp has a spot to hook up a remote wire Quote Link to comment Share on other sites More sharing options...
wannabang Posted June 2, 2013 Report Share Posted June 2, 2013 Yeah, and I'm pretty sure the amps that are signal-sensing do, too. I would always prefer to run the wire. I don't trust frequencies too much. LOL Quote Link to comment Share on other sites More sharing options...
ravishingrocket Posted June 2, 2013 Report Share Posted June 2, 2013 On 6/2/2013 at 5:54 PM, wannabang said: Yeah, and I'm pretty sure the amps that are signal-sensing do, too. I would always prefer to run the wire. I don't trust frequencies too much. LOL Nothing in the specs say anything about signal sensing Quote Link to comment Share on other sites More sharing options...
wannabang Posted June 3, 2013 Report Share Posted June 3, 2013 Then run the wire to the remote out in your HU, or the power wire of your HU, and just remember to turn your HU off every time. Quote Link to comment Share on other sites More sharing options...
ravishingrocket Posted June 3, 2013 Report Share Posted June 3, 2013 On 6/3/2013 at 12:00 AM, wannabang said: Then run the wire to the remote out in your HU, or the power wire of your HU, and just remember to turn your HU off every time. Doesnt it already do that when i open the door? Quote Link to comment Share on other sites More sharing options...
wannabang Posted June 3, 2013 Report Share Posted June 3, 2013 Huh. Yes. Now, that I think of it, I'm not sure why I always had that idea in my head. If you don't connect the remote wire, though, it will always draw current. Quote Link to comment Share on other sites More sharing options...
Tlints2 Posted August 8, 2013 Report Share Posted August 8, 2013 Regurgitating a bit more on this thread. I want to do the same as many of you, but I don't want to go as big. I want to use all stock amplifiers and just upgrade the sub. I'm only wanting to do this for the low frequency that I'm missing out on. A 8" bottoms out at roughly 35 Hz and a 10" will go down to around 24 Hz. How will the stock amp running a Kicker S10C4 sound? I have an extra US Amps AX600DE and Image Dynamics IDMAX 12", but I'm mostly looking to keep it low key and utilize my trunk space for parent things. 14 week old... Anyone upgrade the sub and use the stock amp? I'm guessing that the stock stereo plays the full bandwidth, I should be ok. I'm just wondering if anyone has $.02 for me. Please, thanks Quote Link to comment Share on other sites More sharing options...
stang99x Posted August 8, 2013 Report Share Posted August 8, 2013 I did something like that years ago in my Navigator. Had the stock 8 with the bolted back plate. Take it out, cut the bolt area and then JB Weld with silicone and plexiglass, modify the front for a 10. Worked really well for what it was. Of course, it's not likely you can get the exact volume specs for a 10, but it's better than an 8. I hate crap systems, but honestly the system in the 11 Sport I just bought is Dam fine compared to most any stock system I have ever heard. The bass is a little lacking, but overall i find it quite pleasing. My days of license plate rattling are long behind me now..... Quote Link to comment Share on other sites More sharing options...
wannabang Posted August 9, 2013 Report Share Posted August 9, 2013 I think you'd be surprised how thin you can make a box with the right sub and enough height. I'm building a sealed box for my 15" that currently takes up a ton of space. The box will only be 12" deep, but run across the whole of the driver's side trunk panel leaving plenty of room to store stuff to the right of it. If you were to replace the stock sub, I'd probably build a new enclosure, or buy a stealthbox... quality is 99% enclosure. I'm sure you could fit a ten in if you're willing to cut the plastic, but I'd be careful to say ALL tens go down "so" low. Quote Link to comment Share on other sites More sharing options...
DP96 Posted January 20, 2015 Report Share Posted January 20, 2015 Is there a aftermarket 8" sub that the factory amp will push? I want to change it. But don't want to add aftermarket amp to the factory radio system. 2013 touchscreen/sony system. Quote Link to comment Share on other sites More sharing options...
rwm01 Posted January 21, 2015 Report Share Posted January 21, 2015 (edited) Deleted duplicate post. Edited January 21, 2015 by rwm01 Quote Link to comment Share on other sites More sharing options...
rwm01 Posted January 21, 2015 Report Share Posted January 21, 2015 I installed a Polk Audio DB840DVC in my 2008 Limited but I have a Kenwood DNN991HD head unit. Pretty straight forward bolt in and hook up. Better sound than stock and fairly inexpensive. Quote Link to comment Share on other sites More sharing options...
DP96 Posted January 21, 2015 Report Share Posted January 21, 2015 Rwm01. Are you running the Polk sub on the factory amp? Or aftermarket? Quote Link to comment Share on other sites More sharing options...
DP96 Posted January 21, 2015 Report Share Posted January 21, 2015 Rwm01 Are you running the Polk sub on stock amp or aftermarket? Quote Link to comment Share on other sites More sharing options...
rwm01 Posted January 21, 2015 Report Share Posted January 21, 2015 The stock amp. It's not a "thumper" that passing motorists can feel, but the lows are richer than the stock sub. Quote Link to comment Share on other sites More sharing options...
