Best HID Kit For 2011 Edge
If you have a 2011 I believe you need a 9012 or 9006 kit. While the 9005 may work you may have to adjust the tabs. But if you do a search you will find a ton of posts on this subject. Lately it seems many members have gone with kits from DDM, not sure if they ship to Dubai though.
  On 4/6/2012 at 9:27 PM, c_bova said:
you won't need the wire harness with the 35w kit
Not necessarily the case. Many times this is true but from what I have read here some have had electrical issues becuase the power is pulsed not constant. So this can take a toll on the ballasts and over time they are more likely to fail. Also some have reported that the electronics of the vehicle have been damaged due to the in rush current required to ignite the bulbs. For the few bucks they cost I would error on the side of caution but that is up to the end user.
  On 4/6/2012 at 10:10 PM, abaade said:
HID Harness
Error Eliminator
Adaptor cables
Mounting Brackets
what can i choose?
but if i want this itis ok
http://www.ddmtuning.com/Products/DDM-HID-Kit-D1SR-35W
thx
As mentioned above the harness is a good idea since it will draw power directly from the battery. You don't need error eliminators or adaptor cables. Mounting brackets are up to you and how you want to install. And no you can't use that kit, it is the wrong bulb type for your vehicle.
http://www.fordedgeforum.com/index.php?/topic/9216-hid-kit-retrofit-conversion-installation-video/page__view__getnewpost
Check out this thread by kc300 he has a installation video of a 55w 6000k setup followed his instructions and it worked for me! And the bulb type is 9006 hb4 you pick the color. The kit is from Ddm tuning here is the link http://www.ddmtuning.com/Products/DDM-HID-Kit-Slim-Ballast-35W-or-55W
Edited by Bryan003
