cjd3 Posted May 27, 2012 Report Share Posted May 27, 2012 Late to the game, but did you need to get a flasher replacement for the LEDs, or is the Edge smart enough to blink them properly? Quote Link to comment Share on other sites More sharing options...
Cellbine Posted May 27, 2012 Author Report Share Posted May 27, 2012 The Edge is smart enough with these bulbs to flash properly. 1 Quote Link to comment Share on other sites More sharing options...
PrinzII Posted May 27, 2012 Report Share Posted May 27, 2012 Do you get any bulb out indicator lights on it? Quote Link to comment Share on other sites More sharing options...
Cellbine Posted May 27, 2012 Author Report Share Posted May 27, 2012 No, it was a clean swap of bulbs with no errors or modifications to the vehicle. Quote Link to comment Share on other sites More sharing options...
PrinzII Posted May 27, 2012 Report Share Posted May 27, 2012 I wonder if there is a version that is brighter. Quote Link to comment Share on other sites More sharing options...
fishx65 Posted June 2, 2012 Report Share Posted June 2, 2012 (edited) I've had really good luck with all the leds I've purchased on e-bay for two Edge's. Has anyone purchased a set of these switchbacks from E-bay yet? Looks like I can pickup a set for around 10 smackers. Edited June 2, 2012 by fishx65 Quote Link to comment Share on other sites More sharing options...
PrinzII Posted June 4, 2012 Report Share Posted June 4, 2012 (edited) Do they have a 5000K version of those switchbacks? N/M - Found 'em http://www.v-leds.com/5K-TYPE-2-DUAL-COLOR-p7114832-1-2.html Edited June 4, 2012 by PrinzII Quote Link to comment Share on other sites More sharing options...
Cellbine Posted June 4, 2012 Author Report Share Posted June 4, 2012 Good find. I think the switchbacks that I have are 6,000k. I love that I have the type 1 version. When the turn signal is applied on Type 1, the LEDs alternate between white and amber. With Type 2, the switchbacks only display amber flashing LEDs and then go back to white when the signal is turned off. Thats the only reason I'm not going to get these 5,000k. Although they would compliment my 5,000k HIDs a little better. 1 Quote Link to comment Share on other sites More sharing options...
PrinzII Posted June 4, 2012 Report Share Posted June 4, 2012 Cellbine: Thanks for the heads up. I want the ones like you have but 5000K to match my HIDs. Quote Link to comment Share on other sites More sharing options...
Cellbine Posted June 4, 2012 Author Report Share Posted June 4, 2012 Here is a pic I shot a while back. I think the color difference is negligible, but the lines could be blurred a bit because of the camera. 35W 5,000k bulbs. Quote Link to comment Share on other sites More sharing options...
candurin Posted June 4, 2012 Report Share Posted June 4, 2012 So does the edge use the standard or CK version? Quote Link to comment Share on other sites More sharing options...
Cellbine Posted June 4, 2012 Author Report Share Posted June 4, 2012 Standard, No additional wiring was required for my '11 Limited. Quote Link to comment Share on other sites More sharing options...
PrinzII Posted June 4, 2012 Report Share Posted June 4, 2012 Cellbine: Then, I will go that direction based on the picture. Quote Link to comment Share on other sites More sharing options...
OnlySkillz Posted June 5, 2012 Report Share Posted June 5, 2012 Plan on doing this! I prefer the Type 2, I think it'd be easier to distinguish from amber and nothing during a turn. Also, since I don't have the car yet, can someone lay out how the light combinations work? What light modes are there, and which ones are turned on when a certain option is selected? Quote Link to comment Share on other sites More sharing options...
Cellbine Posted June 5, 2012 Author Report Share Posted June 5, 2012 On 6/4/2012 at 8:57 PM, PrinzII said: Cellbine: Then, I will go that direction based on the picture. PrinzII, When I go back and look at the pic I posted, I have to tell you that the camera fills a lot of space in with the light. The bulbs light pattern does not fill in the turn signal housing like it shows in the picture. You can get a better representation of how the look by watching the second video I posted on day and nighttime driving located on the first page of this thread. Here: http://www.fordedgef...all/#entry77908 That being said, the LED color isn't an exact match with the HIDs, but I think the slight difference in color actually helps distinguish the turn signal a little bit more. Go with which ever color you gut feels is the right one to get. I just want you to make the best decision for your Edge. On 6/5/2012 at 1:46 AM, OnlySkillz said: Plan on doing this! I prefer the Type 2, I think it'd be easier to distinguish from amber and nothing during a turn. Also, since I don't have the car yet, can someone lay out how the light combinations work? What light modes are there, and which ones are turned on when a certain option is selected? Sure Skillz, here is the break down and I hope this answers your questions. Ill first tackle how the switchback works. Short and simple, when your parking/headlights are on there is a constant current sent to your turn signals. This current is what tells the LEDs to display white. They will continue to display this color until you hit the turn signal or hazard lights. At that point in time, and additional current is sent to the LEDs which tell it to flash amber. Once the turn is complete, you turn off the turn signal, or turn the hazards off, the LEDs go back to displaying a constant whtie. Second, there are two types, from the site I got mine from, that are available. Here is what I posted earlier on the subject: On 6/4/2012 at 7:17 AM, Cellbine said: When the turn signal is applied on Type 1, the LEDs alternate between white and amber. With Type 2, the switchbacks only display amber flashing LEDs and then go back to white when the signal is turned off. Quote Link to comment Share on other sites More sharing options...
PrinzII Posted June 6, 2012 Report Share Posted June 6, 2012 Cellbine: Thanks for the clarity. I'll try the type twos since it's the same color as my HIDs. When I get them, I will let you all know how they fare. Quote Link to comment Share on other sites More sharing options...
candurin Posted June 16, 2012 Report Share Posted June 16, 2012 Just installed mine and only the ambers work. No white lights or DRLs. Weird! Just emailed them and we'll see what happens. Quote Link to comment Share on other sites More sharing options...
fishx65 Posted June 19, 2012 Report Share Posted June 19, 2012 Just got a cheap set I purchased on E-bay and they are really bad. One of them stays orange with the parking lights on and blinks white!!!! They also cause the fast blink and the white leds do not shut off when the orange ones blink. Only out 8 bucks so not a big deal but just wanted to let everyone know that the cheap e-bay switchbacks are garbage. Quote Link to comment Share on other sites More sharing options...
Cellbine Posted June 19, 2012 Author Report Share Posted June 19, 2012 Sorry to hear that Fish. Are you still considering ordering the ones like mine? Quote Link to comment Share on other sites More sharing options...
fishx65 Posted June 19, 2012 Report Share Posted June 19, 2012 C, Gonna get the DDM's put in first, which should be here any day, and then maybe order a set of switchy's from V. Wish I could find the ones V sells for a normal price but I have not seen any type 1's besides his. Quote Link to comment Share on other sites More sharing options...
shantz Posted June 20, 2012 Report Share Posted June 20, 2012 I also just received a set from Ebay - I'll let you know how they work out Quote Link to comment Share on other sites More sharing options...
fishx65 Posted June 20, 2012 Report Share Posted June 20, 2012 On 6/20/2012 at 9:14 PM, shantz said: I also just received a set from Ebay - I'll let you know how they work out Please do Shantz. The ones I got were just under 9 bucks and they were cool enough to refund my Paypal because of the defective one. They didn't even ask me to send them back. Very curious to hear how yours work out. Quote Link to comment Share on other sites More sharing options...
wlepse Posted June 21, 2012 Report Share Posted June 21, 2012 Wow nice CS...I don't usually have that kind of luck on Ebay Quote Link to comment Share on other sites More sharing options...
Tacyon Posted June 21, 2012 Report Share Posted June 21, 2012 I ordered a set like Cellbine about 2-3 weeks ago .... still haven't received mine. I called and kindly had my attention drawn to the "back ordered" on the web link as well as my email. These are the 6k type 1 that are on back order. Oh the wait ! Quote Link to comment Share on other sites More sharing options...
mtbalser Posted June 21, 2012 Report Share Posted June 21, 2012 Same here due in about middle of July. Quote Link to comment Share on other sites More sharing options...
