full_jingbang Posted March 31, 2012 Report Share Posted March 31, 2012 I Just bought a ford edge 2007 SEL AWD. I need to change the tires. the original tire size mentioned is 235x65xR17 I cant find these tires here, Want to know if any other size will fix on 17" rims ??? regards, Quote Link to comment Share on other sites More sharing options...
bbf2530 Posted March 31, 2012 Report Share Posted March 31, 2012 (edited) I Just bought a ford edge 2007 SEL AWD. I need to change the tires. the original tire size mentioned is 235x65xR17 I cant find these tires here, Want to know if any other size will fix on 17" rims ??? regards, Hi full_. :D Yes, there are various 17" choices which would be usable on your Edge For example: you could one size wider, to a 245/60-17 (a slightly smaller diameter than stock), or a 245/65-17 (a slightly larger diameter than stock) etc.. Also, in addition to the size concerns, be sure you purchase tires with an equivalent or slightly higher load rating than the stock/original tires. However, you should really speak to a competent tire shop in your area and see what is truly available. Or if you are ordering over the Internet etc., speak directly to a representative for the best advice and recommendations, since they will know what they do and do not offer. Let us know how you make out and good luck. :beerchug: Edited March 31, 2012 by bbf2530 Quote Link to comment Share on other sites More sharing options...
full_jingbang Posted April 1, 2012 Author Report Share Posted April 1, 2012 thanks dear bbf2530 Actually we do not have "tire experts" in this part of the world I have 255/60/R17 ... will they work ? these are the same size which fit on Trail Blazer. Please advise. Thanks Quote Link to comment Share on other sites More sharing options...
carbonedge+ Posted April 2, 2012 Report Share Posted April 2, 2012 The Toyo Open Country H/T comes in the OEM size (235/65/17); that's what I would recommend. Quote Link to comment Share on other sites More sharing options...
