edge22" Posted August 22, 2007 Report Share Posted August 22, 2007 Has anyone heard anything about aftermarket tail lights for an edge going into production? Quote Link to comment Share on other sites More sharing options...
rl07edge Posted September 12, 2007 Report Share Posted September 12, 2007 Has anyone heard anything about aftermarket tail lights for an edge going into production? Haven't seen any lights, but saw these on ebay! http://cgi.ebay.com/ebaymotors/FORD-EDGE-T...1QQcmdZViewItem Quote Link to comment Share on other sites More sharing options...
edge22" Posted May 14, 2008 Author Report Share Posted May 14, 2008 For the love of God!! You would think someone, by now, would have put out LED taillights for the edge! anyone heard anyhing? HELP!! Quote Link to comment Share on other sites More sharing options...
Lex Talionis Posted May 14, 2008 Report Share Posted May 14, 2008 (edited) Am I missing something?? why can't you just replace the bulbs with LED bulbs like numerous people have done here already? search the LED threads.. just buy LED bulbs (and resistors if you do turn signals) and make it happen. easy. Edited May 14, 2008 by Lex Talionis Quote Link to comment Share on other sites More sharing options...
edge22" Posted May 14, 2008 Author Report Share Posted May 14, 2008 The factory tail lights are just a little too flashy for my liking. I'm looking for a black set of led tail lights, where the entire break light part of the lens is black and filled with individual led bulbs. minimal chrome, I just want an led aftermarket look. Quote Link to comment Share on other sites More sharing options...
Kanatronic Posted December 21, 2008 Report Share Posted December 21, 2008 Just a heads up from Daniel Stern: "...I must caution you in the strongest possible terms that the "LED bulb" idea raised in that thread is not a solution to the problem, and it is extremely dangerous and quite illegal. "LED bulbs", even the fancy ones with multiple emitters facing various directions, cause the vehicle's lamps not to perform in a safe or legal fashion with respect to the intensity of light emitted, the ratio of bright (brake or turn) to dim (tail or park) intensity, and the angles through which the light is distributed. If a vehicle is involved in a collision, and the lighting equipment is found not to be equipped with a legal light source or otherwise not to be performing in the intended manner, the vehicle owner can be exposed to very significant liabilities..." These are the only aftermarkets I would consider as they will not emit as much heat as they have a polimer instead of plastic on the base, and they are also rated for 14volts continuos use, so they will last at least 5 times as much: The amber (front park/turn) ones are here... The clear (rear brake/tail) ones are here... I replace myself the front already, they are plug and play, the rear the same but will do it tomorrow, the intensity of light is more ro less the same to me... Quote Link to comment Share on other sites More sharing options...
