exodus Posted March 28, 2012 Report Share Posted March 28, 2012 I added these LED reverse bulbs how do they look Quote Link to comment Share on other sites More sharing options...
Dingo Posted March 28, 2012 Report Share Posted March 28, 2012 Looks good. Wish you had told me. I have some led backup bulbs here and some led amber front turn signal bulbs, too. Quote Link to comment Share on other sites More sharing options...
Dingo Posted March 28, 2012 Report Share Posted March 28, 2012 Looks really good Exodus. You said they are LED? What type did you use and are they brighter than the stock incandescent bulbs? I link to them would be gret. Dingo, Since you have these reverse LED bulbs laying around after you installed your retina searing anti-tailgater laser cannons, whould you be willing to sell them to me? Are they brighter than the OEMs? Sending a PM... Quote Link to comment Share on other sites More sharing options...
exodus Posted March 28, 2012 Author Report Share Posted March 28, 2012 I used the tower led bulbs from superlumination.com they are 921 bulbs in 6K Quote Link to comment Share on other sites More sharing options...
joshaustein Posted March 30, 2012 Report Share Posted March 30, 2012 I'm waiting for KC300's guide on changing the reverse lights.... Cause this sounds like another job I wouldn't mind tackling, but i've become reliant on KC's videos 1 Quote Link to comment Share on other sites More sharing options...
Dingo Posted March 30, 2012 Report Share Posted March 30, 2012 Dude... Remove the 2 8mm bolts from the taillight. Pull straight back. Find the base for the reverse light. Turn 1/4 turn. Remove. Grab bulb. Pull. Test. Reverse. Quote Link to comment Share on other sites More sharing options...
joshaustein Posted March 30, 2012 Report Share Posted March 30, 2012 I'll have to check that out... I haven't really examined the tail light section before. I see that they have 2 variations, i'm thinking this is the correct bulb: 921 18 LED Tower LED Bulb. Only 15mm diameter x 46mm overall. 18 (3 forward + 15 side facing) Super Hi-Powered Super-Flux leds Emit Light in All Directions. http://superlumination.com/906.htm These are the ones that are brighter than OEMs? Are these the same as the MAP lights, or are these a little longer? They look similar though. Quote Link to comment Share on other sites More sharing options...
Dingo Posted March 30, 2012 Report Share Posted March 30, 2012 (edited) Those would fit. The ones I have for sale are brighter. Edited March 30, 2012 by Dingo Quote Link to comment Share on other sites More sharing options...
joshaustein Posted March 31, 2012 Report Share Posted March 31, 2012 Sort of a side question relating to this. Once i get the tail light housing off, could I just change out all the bulbs in there for LED? I sort of recall reading something about the brake lights needing some extra stuff because they Dim... but i could be making that up. Could I replace the amber turn signal bulbs for LEDs without any other devices? Thanks! And Dingo I sent you a PM about those bulbs. Quote Link to comment Share on other sites More sharing options...
Dingo Posted March 31, 2012 Report Share Posted March 31, 2012 All of mine are LED, except for the backup lights, which are HID. I also used red LEDs in the blinker. I didn't like amber in the tails. Quote Link to comment Share on other sites More sharing options...
candurin Posted May 15, 2012 Report Share Posted May 15, 2012 Dingo, would the 912 HID kits work, no problem? Just concerned about heat build-up and melting the housings. Also, what are the specs on the bright LED's your referring too? Just trying to decide if I want to gamble with HID kits or try and get the brightest LEDs, I can. Thanks! FYI, here's the HID kit I am looking at: http://www.ebay.com/itm/HID-Reverse-back-up-Fog-light-kit-12V-15W-T10-921-194-W5W-4300K-White-Short-lamp-/170827281493?pt=Motors_Car_Truck_Parts_Accessories&hash=item27c6197455&vxp=mtr Quote Link to comment Share on other sites More sharing options...
Dingo Posted May 15, 2012 Report Share Posted May 15, 2012 Dingo, would the 912 HID kits work, no problem? Just concerned about heat build-up and melting the housings. Also, what are the specs on the bright LED's your referring too? Just trying to decide if I want to gamble with HID kits or try and get the brightest LEDs, I can. Thanks! FYI, here's the HID kit I am looking at: http://www.ebay.com/itm/HID-Reverse-back-up-Fog-light-kit-12V-15W-T10-921-194-W5W-4300K-White-Short-lamp-/170827281493?pt=Motors_Car_Truck_Parts_Accessories&hash=item27c6197455&vxp=mtr I don't like the looks of that kit. The base wouldn't work well with the lamp socket, and the connector looks like trouble. The LEDs are these: http://www.v-leds.com/5K-WHITE-19-LED-8W-HIGH-p9507296-1-2.html Quote Link to comment Share on other sites More sharing options...
candurin Posted May 15, 2012 Report Share Posted May 15, 2012 Thanks for the fast response... I'll steer clear of the HID's and go with your V-LED recommendation. Thanks! Quote Link to comment Share on other sites More sharing options...
PrinzII Posted May 27, 2012 Report Share Posted May 27, 2012 This is on my to-do list... Quote Link to comment Share on other sites More sharing options...
DFallenAngel Posted February 8, 2013 Report Share Posted February 8, 2013 interesting..... 1 Quote Link to comment Share on other sites More sharing options...
mtbalser Posted February 8, 2013 Report Share Posted February 8, 2013 Hey Dingo, what HID kit did you use for your reverse lights? Quote Link to comment Share on other sites More sharing options...
Dingo Posted February 8, 2013 Report Share Posted February 8, 2013 It's not a kit anymore. I've changed and added so many parts that they're just kind of their own thing. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted February 8, 2013 Report Share Posted February 8, 2013 That be bright alright! Quote Link to comment Share on other sites More sharing options...
mtbalser Posted February 8, 2013 Report Share Posted February 8, 2013 OK, thanks for your quick response! Quote Link to comment Share on other sites More sharing options...
PrinzII Posted February 10, 2013 Report Share Posted February 10, 2013 I have to return one of my LEDs to V-LEDs because it stopped working. Quote Link to comment Share on other sites More sharing options...
RobbN Posted February 12, 2013 Report Share Posted February 12, 2013 That V-Led link did not work for me I would be ver interested in the best LED option(s) for my edge - Backup lights, tails, and Blinks. I am also interested in the front LED's but I saw the switchback video and they did not look bright and could not even tell they were working when the headlights were on. Can I get some V-Led Part numbers ?? thanks - 2011 SEL Edge Quote Link to comment Share on other sites More sharing options...
Tennesseefan Posted March 19, 2013 Report Share Posted March 19, 2013 For what its worth, I used Cree LED bulbs in my reverse lights. Very happy. Got them on Ebay. www.superbrightleds.com for my interior LED swap Quote Link to comment Share on other sites More sharing options...
