Yes! I bought our '07 Edge FWD in May, and replaced both rear wheel bearing assemblies in July after the right rear started howling on the way home from a road trip. Overall, it's an easy job - I say that because I am an auto tech - but the thing is, even with the lower mileage, the hub corroded itself into the cast iron spindle assembly, so I negotiated it out with an air hammer. Use anti-seize on reassembly and it all goes back together easily. Four T-55 or T-60 torx type bolts hold the bearing assembly on the knuckle. Oh yeah, you'll most likely have to replace the ABS sensors too, as they like to fall apart when you remove them from the bearing. Again, easy fix. I bought two Timken brand wheel bearings and both rear Motorcraft ABS sensors from RockAuto.com and paid around...I think it was $200-$225 shipped. Going into buying the Edge, I knew that they had wheel bearing issues, but not a big deal to replace. I think it's a supplier issue (SKF, I believe? Not FOR SURE) Overall,my wife and I love this car, it rides nice, good power, looks great and tons of room.
