forbes
Everything posted by forbes
Anyone? To clarify, I have reviewed many posts on our EDGE lights but they are mostly a few years old. I asked because there are so many new choices on Amazon . I was interested to know actual users experience before I choose. Also,the manufacturers descriptions and videos are all glowing (lol pun intended)
I have a 2012 Edge with projector lenses and halogen bulbs. I want to change them. I spoke to a Ford service man that I know and he said that the LED conversions have a bad habit of melting the headlight housing. I thought I would switch out to HID's with a remote ballast. In reading posts, I can't find any recent information. Is there anyone out there who has done the HID conversion? Whose product did you use and was it successful? Thanks in advance.
2017 Edge Terrible GPS Performance
forbes replied to juscruzn's topic in Audio, Backup, Navigation & SYNC
New to California, I drove local streets in Berkeley and then back to Marin today. The Nav was flawless .( 2012 not updated).. Much better than my 2016 MB or my google maps on iphone....................Just saying -
Thanks !!!!!! I qualify for the " Field Service Action Item" I guess it cannot be called a Recall since it is not a safety issue mandated by NTSA ? BTW my Ford Edge has been the most reliable vehicle I ever owned in fifty years(I guess I'm old). Quite a few unreliable BMW's and Mopars,but not the EDGE!
hi, 2012 with nav ,touchscreen, and snyc. Sound system, in this case the radio randomly turns itself on.Any suggestions appreciated.. Alan
The write up and photographs on the spark plug replacement are fabulous and great help. Many thanks. I would add one change. Since the spring clamp on the brake booster line is such a difficult reach and removal, I did not use the old clamp but rather used a stainless steel screw type clamp. This allowed me to slide the hose back onto the plenum and then reach in with a long screwdriver and tighten the clamp. Also, use a small amount of silcone grease to make the hose slide on easier.
Not a chance -That is called theft!!
Not one response!
Anyone know what company manufactured the unit ? Maybe I can obtain a knob from them
The knob broke-heat fatigue of cheap plastic. It is not available from the dealer. The parts manager and the service writer both said you have to buy a whole new radio. For a 50cent part? I do have an extended warranty,$100 deductible,but still ridiculous. All suggestions appreciated.
I got a set of OEM 18 inch alloys from an owner who switched to 20s. I fitted them with Hankook I Pike snow tires. I am going to have to replace my OEM Michelins and thought that since I have winter tires on separate rims that I could get summer tires rather than All Seasons. They are 245/60/18. Any recommendations will be appreciated. It looks like Tire Rack and a few other suppliers have no dedicated summer tires. BTW the OEM MIchelins ride like wooden wheels.
I just purchased Hankook i*Pike RW11 winter tires in 245/60R18. Seem very good so far,and we have had snow. hankook.pdf
My Lincoln MKX with AWD has 18 inch rims. Can I put 17 inch rims from a Ford Edge on the vehicle, assuming I use the correct profile tire so that the outside circumference remains the same? The reason I ask is that the rims have to clear the calipers, and it has been stated in various forums that the brakes on AWD Lincolns and Edges are bigger than the FWD's and that is why all of the AWD's have18's
Just got the vehicle back from the dealer. They replaced the variable camshaft tensioner phasers,as per a TSB (9-13-10) They said that if the MKX was not under warranty that the cost would have been over $2000.
Took the vehicle in to my local Ford/Lincoln dealer. They phoned me later in the day to say that it coded for a bad cam position sensor. It will take them about three days to repair as they have to tear down the front of the engine to the timing chains to get to the sensor. I'll let you know more details when I get it back. Thanks for the responses. Alan
The check engine light came on today on my 2008 MKX, only 24,000 on the odometer. It is running fine, no apparent misfires or flaws. Any ideas will be helpful. Thanks, Alan
Remote Start and Programmable Key
forbes replied to forbes's topic in Interior, A.C., Heat, Interior Trim
I found the unit under the dash. It is an Audiovox AS9076. Has nothing to do with the memory seats. So, Key ' A ' will program to either memory one or two on the door. Key 'B' will do neither. Stealership says it is the remote start module. BTW: Stealer also said "you bought it used did't you, so we don't care. -
I have a 2008 MKX that I purchased used. I can program the memory seats to the buttons on the door but I am able to link key #1 with the door button or key #2 with the door button. Took the car to the dealer and they figured out that I have an after market remote start installed on the car. To start the engine, you press lock, unlock then lock on the keypad. The car starts shortly and the doors are locked. Pressing the unlock on the keypad opens the door. The dealer said that the aftermarket remote starter is blocking the functions of the keypad link to the memory seats. Two questions: 1. What is the location of the remote starter so I can see if it is a Ford product or an aftermarket unit from someone else. 2. Is there a way to program the key to the memory seat?
I'd like to get navigation for my 2008 MKX. Any suggestions for a salvage yard or other source will be appreciated Thanks
