railroad
Everything posted by railroad
Sounds like the body is flexing. If so, there is not much you can do, short of adding subframe connectors. To reduce the noise, wipe all the rubber seals around the windows and doors with Armor All or equivalent. It will not stop the flexing, but might reduce the noise. good luck.
There are LED replacements for all of the common filiment type bulbs. They do not require changing out the sockets. Most truck stops have them. Speedway automotive also carries them. After replacing them, your turn signals may not work. The LEDs do not draw enough current to activate the flasher switch. The automotive market also sells a plug in load cell to correct for this, so again no modifications required. There may be a problem with the sockets melting, but make sure you are not resting your foot on the brake while driving. The bright side of the bulb does generate a lot of heat.
Congrats on the mileage, but I do not think you are doing your fuel pump any favors by running it low on fuel. I prefer to keep my fuel injected, internal pump vehicles above 1/4 of a tank.
Your pads look good. The rotors look like they were not turned the last pad change, no biggy, if you are not getting any grinding or shake in the front end. Looks like the Chicago salt is doing its thing on the bare metal. Probably normal for the area. A lot of brake jobs require new rotors now, when the pads are gone. I guess it is the price we pay for good pad material and stopping 4000 lbs. Yours looks like normal wear. Keep driving. Brakes usually last something in the neighborhood of 50 to 70K miles. If you are on the upper end you are doing well, just keep an ear out for the grinding sound.
I think this is a motor/transmission mount issue. I have the same issue with my 03 Escape, even after replacing 3 mounts. I own a 2010 MKX and have not exp the problem yet. The reason the vib manifest itself at idle and not at speed is because the engine torque/movement unloads the mount or contact area that is transmitting the vib. With the problem occurring at such low mileages, I would document it so, Ford can address it, when they get enough flack about it.
It would have to really pick up on the hp and or mpg to entice me. Sounds like a six cylinder trying too.
Get the ones from Lowes and get your salesman to give a you bottle of touch up paint. My salesman stiffed me for $13. I am starting to look for a new truck. Guess which salesman will not get the sale.
Just keep running good gasoline, add a can or bottle of injector cleaner every month or so and leave the injectors alone. You might want to change the fuel filter sometimes after 100K.
Real unusual that would be related to a plug change. See if you bumped loose a hose or electrical connection. Maybe even on the air filter duct.
Anyone have information on installation of the caliper covers? The ad says no tape or glue. That makes me think there might be a snap spring friction fit. At the listed price it is not something I want falling off on the highway.
Ford uses some preformed hoses that connect the filler flange to the tank. They had a bad problem with some Taurus's some years back. It seems the preformed bend was collapsing and not letting the gasoline flow freely. I would either get under the car or put it on a lift and see if the hose is kinked. A second problem may be the vent hose. I do not know if the Edge's have one, but some have a separate smaller line that runs from the tank to the filler neck for venting air as the gasoline comes in. An innovative mechanic may be able to blow some low pressure through this line to verify it is clear, with the cap off, no open flames, standing clear if some liquid is forced out, with the tank way less than full, very low pressure,,,, just some of the stuff you would think would be common sense. Also check for a TSB on this, might be the 1st thing to do. good luck,
Ditto on the quick oil change shops. It sounds like you do mods on your vehicles that instill more confidence in the oiling system. Nothing wrong with improving the functioning of a system. I am sure the extra filtration and cooling help the longivity of the oil and it sounds like it fits your operating schedule. My trucks never had the luxury of long continous drives. They may be towing a 60 T Bird through 3 or 4 states, if that is a long haul, but mostly driven to work (60 miles) until I retired in 2008 and other than being a loaner to my son and brother, just do small hauling jobs. By the way, I did change to Brad Penn motor oil, after the name brands pulled ZDDP from their over the counter stuff. I used to annal about my motors and hot rods. I would change stuff on a new vehicle to satisfy my desire for improvement. Now I just do a decent maintenance schedule and run what the factory delivered. Hope you continue to get good results.
Well I guess you are definitely not one of the 3000 mile oil change herd. I am not the most informed on Amsoil, but know of it and some of its claims. For what you are saving or what ever the advantages to a 25,000 mile oil change would be, I would not be comfortable. I have an 88 and 93 Ford. I have changed the oil, real close to 5000 miles since new. Both engines are within 5000 miles of 300,000 miles. I mostly used Castrol 20w-50 year round. Neither engine uses any oil amount that requires adding. I am sure Amsoil is a very good lubricant, but I cannot even see 15,000 miles as doing anything good for your engine. Your engine is what you are trying to maintain and protect, not your wallet or bragging rights. I might consider 7000 miles, but would still not be comfortable with 10,000. Don't come unhinged on me, on this. I am just speaking from what I would do. Amsoil is selling a product and you are a potential customer. No matter how loyal we are to a brand, all compaines are in it to make MORE money. If I wanted to stay with Amsoil, I would back my oil changes down until I got an anaylsis that was good. If you are still in warranty, you may want to consider how that much mileage would figure in on a claim, not that I would volunteer it. If you take into consideration the price of an oil cooler. It doesn't sound like you are going to buy a J C Whitney model, installation and the price of Amsoil, the risk of increasing the engine wear, are you really coming out ahead anywhere in the whole scheme. I hope you have taken this as genuine concern that you are not on the best path and reconsider your options.
You did not state what your driving conditions are. I did notice you are in Texas where, I am sure the heat can be extreme. Two situations that might put extreme heat in your engine are extended high loads, like towing or high speeds not in overdrive. Second, would be extended idling in close traffic with the A/C and other accessories on. With that on the table, if you are exceeding these conditions, I guess an oil cooler is an option. I may be totally wrong on this, but I would associate oxidation more with not getting the moisture out of the engine with short trips or run times. Since you have gone to the trouble to have an oil analysis, I will let the diagnosis you have be correct. Maybe a less expensive solution would be changing types or brands of motor oil. Most people that would spend money on an oil anaylsis, would have no problem in paying for full synthetic motor oil. Since that information is not provided, my guess is yes. If you have having problems with full syn and agree heat is the problem, you might considered shorter oil change intervals. I hope you are not one of those in the herd of 3K mile oil changes. If you are doing all the options listed and got the negative results stated, I would consider a cooler.
I think there is a long thread on this issue. My MKX had the front bracket riveted on. I drilled the rivets out, leaving two small holes in the front bumper. Lowes hdwre sells some plastic push pins that fit right in and almost flush. If I had thought to paint them with the touch up paint, I think they would be totally un noticible. Bumper looks much smoother.
You need to start using a different parts store. Doing a voltage check on the battery is not very useful. NAPA has a diag hook up that will show the voltage, drain while starting (amps), and alt voltage. Or you can put a voltage meter on the battery and see if it increases to 13.8 to 14 volts when the engine starts, indicating the alt is doing its job. All indications are for a battery though.
I got an email from Steeda for a 20% off discount code on Steeda products. They have some stuff specifically for the Edge and MKX, if anyone is in the market. The code is black.
Tire Cupping on insides of all tires.
railroad replied to LAJAMA's topic in Brakes, Chassis & Suspension
Your tires are out of balance. Get them balance ASAP. If the cupping is severe you will not be able to wear back to an even tread. At 58,000 you should not have needed an alignment, unless you hit something. You may need to find another tire store, if they are responsible for selling you 3 alignments. -
I would go by my favorite tire store and ask them to pull the tires and look for any signs of something rubbing. If nothing shows up there, ask them to put it on the lift and see if anything looks odd on the floor pan. It sounds like she ran over something or something went under the car. It could have been in a tire area, hence the vib. The tire people can turn the wheels, checking the halfshafts. Pop the hood and check the fan belt and cycle the a/c on and off. Unless it does it again you are just searching for a clue. good luck,
It must have not provided any pep or improvement in mpg. Most of the air intake kits I have been exposed to, only make more noise under kick it acceleration. I would give it a chance, but if mom has spoken??
Nothing there to justify using a qt of oil. If it happens again and you do not want to try 10w-30, I would try a different brand of oil. 90K is nothing on an engine that has been maintained and not been run hot. If you consume another qt and are not ready for a change, I would add a qt of 10w-30.
Check your engine vent system, pcv, and look in your filter box for excess oil. Forget that compression check, improper breakin, If you have not run the engine hot or low on oil, you probably do not have a head gasket problem. Check your oil and water for contamination, mixing of either. The blue smoke may have been there, you just noticed it after coming up low on oil. If the engine is running good, after adding oil back to full, drive it. Next oil change, I would run 10w - 30. Being an 08 model, how many miles on it, how often do you change oil, and what kind of driving do you do? Sometimes I have to recount how many qts I pull down for an oil change. good luck,
If you are running the big rims, ie, 20", you can find some relief in going to something like 18" and keep the tires with a low profile, if the roads will allow. This is not a perfect solution, but will give you a little more umph. Also, be aware the speed o may not be accurate.
Probably Ford's programing for mpg. I am sure the tq converter is locked until you try to accel, then it has to unlock and drop down a gear or two to accel. 6th gear and lock up probably too weak to accel a 4000+ vehicle, needs to adj for accel. Might try locking out the OD, see if it is better and mpg doesn't take a nose dive.
