gary712
Everything posted by gary712
Anyone installed this remote start?
gary712 replied to fit1446's topic in Alarms, Keyless Entry, Locks & Remote Start
no it does not.that unit has to be wired in under the drivers dash -
it is there. more green/tan than green/brown
Alarm engages while I'm driving
gary712 replied to hannieFbaby's topic in Alarms, Keyless Entry, Locks & Remote Start
peter, which alarm/rem start do u have? is it a ford unit or aftermarket? try to post a picture of the remote and I will try to help you -
Remote Start inop 4 honks
gary712 replied to pakus35's topic in Alarms, Keyless Entry, Locks & Remote Start
ford remote start on the edge is programmed for no tach to program key on foot on brake hold button till 3 beeps. foot off brake push button 1 time 4 beeps push button again 5 beeps now touch brake on n off 1 beep look at LED on harness push remote start fob 1 time n LED will go on. turn off key all done -
Now thats a horse of a different color. 2010 edge reverse wire-green/brown drivers kic panel in harness going to rear of car
Stalls when door opened
gary712 replied to Gr8ride's topic in Alarms, Keyless Entry, Locks & Remote Start
Ford remote start does that so that MY FORD KEY works. The car must see one of the ignition keys start the car for MY KEY to work. It can be programmed to be over-ridden.ask your dealer to do it -
reverse light in 14 edge blue/white in driver kick panel pin #13 32 pin black plug
OEM Navigation Radio Installation after purchase
gary712 replied to rl07edge's topic in Audio, Backup, Navigation & SYNC
the steering wheel switch has to be changed for the sync to work. after that it has to be rewired to work correctly. -
if this happens on AM and FM stations ck antenna
Viper 5706 Engine Cut-off Issue
gary712 replied to mestguy182's topic in Alarms, Keyless Entry, Locks & Remote Start
for tach wire use a wire from from one of the fuel injectors. pin 1 grn/blu gry/yel pur/gry yel/org brn or grn/wh -
it sounds like the RS is programmed for tach. All the newer fords do not require a tach signal. I am not familar with the viper. Just go back into programming and set it for no tach or try voltage or hybrid or whatever they use that has a no tach setting. -
Program New Key Fobs
gary712 replied to testedone's topic in Alarms, Keyless Entry, Locks & Remote Start
it sounds like it is locked out. You will need the dealer IDS (computer) -
depending on what year your edge is you can have the dvd play thru your radio system.from the audio out RCA jacks plug into the RCA jacks in your car or the 3.5 mm audio jack. switch the radio to entertainment or audio out
the radio is powered up by the can-bus.leave it where it is
sync
Ford factory alarm, OR aftermarket ?
gary712 replied to GNERGY's topic in Alarms, Keyless Entry, Locks & Remote Start
most likely he does not not have a push to start limited otherwise he would also have remote start.best option is ford remote acess .it gives alarm. remote start cell phone activation of remote start and e-mail alerts if car is broken into -
Whats required for installation of new head unit.
gary712 replied to jeessse's topic in Audio, Backup, Navigation & SYNC
You need the new head unit,a radio harness, an installation kit, and an antenna adapter. Nothing else. -
it would require getting to the back of the outlet you want to rewire.cut the positive wire from the outlet and rewiring to fuse box or ignition switch. If you are not comfortable doing this you can go to a car stereo installation store and have it done.
the good news is if you have a 2008 edge it is a seperate tuner and not part of the head unit.the tuner is mounted in the hatch area on the left side under the plastic panel.If your radio is not navigation I have new ford radios very reasonly priced. PM me if interesed. Gary
airbag warning light stays on
gary712 replied to lpgao's topic in Alarms, Keyless Entry, Locks & Remote Start
try disconnecting battery for 30 seconds and reconnecting -
Alarm Stuck in Valet Mode
gary712 replied to Dtoo's topic in Alarms, Keyless Entry, Locks & Remote Start
if it is in valet mode the LED will flash twice pause flash twice and keep doing this. To get out of valet you have to turn ignition on and off 3 times rapidly without starting car. -
2007 navagition system questions
gary712 replied to allport's topic in Audio, Backup, Navigation & SYNC
post a picture of the mirror -
bluetooth was not available in ford nav until 2008. do u have a factory nav system?
