pbmitch
About pbmitch
1,050 profile views
pbmitch's Achievements
  1. These are never used Cordura front seat covers made for the 2007 Ford Edge. Extremely durable, they are custom made to fit the contours of each seat. Side airbags are unobstructed for safety. Bottom of seat cover is separate from back and is held in place with adjustable straps under seat. Back of seat cover is held in place by a Velcro closure that prevents any movement or slipping of cover. Head restraint covers are also held in place with the same type of Velcro closure. Large pocket on back of seat covers. These are very snug fitting foam-padded covers that look totally custom once they are in place. Asking $125 for the pair (plus shipping and insurance). My email address is pbmitch@cox.net
  2. The four vents together with tax totaled $180 purchased/ordered at my local Ford dealer. Each vent had a different price, strangely enough. It's worth it to now have control of air flow. The original vents were worthless.
  3. Replaced the four vents per your helpful instructions. Thank you! Worked out fine. I found that for the two outer vents bending the release tabs inward inside the housing after removing the louvers allows for easy removal. What a difference now in the airflow control. I highly suggest '07 and '08 owners to make this switch.
  4. I just did as you did last year and bought the four 2009 air vents for my '07 Edge. I read your post that changing them was pretty easy. How did you go about doing that? Do you have to remove part of the dashboard? I'd appreciate any help.
  5. I just picked up four 2009 Edge SE A/C vent louvres to switch out the vents in my 2007 Edge SE. The newer ones are a better design for directing air flow and allow you to completely close them off. Does anyone know what the procedure is for removing the old vents/louvres and installing the new ones?
  6. These are brand new Cordura front seat covers made for the Ford Edge. Extremely durable, they are custom made to fit the contours of each seat. Side airbags are unobstructed for safety. Bottom of seat cover is separate from back and is held in place with adjustable straps under seat. Back of seat cover is held in place by a Velcro closure that prevents any movement or slipping of cover. Head restraint covers are also held in place with the same type of Velcro closure. Large pocket on back of seat covers. These are very snug fitting covers that look totally custom once they are in place. I'm selling these for $125.00. Just decided not to use them. Buyer pays for shipping and insurance. Will accept money order or cashier's check only. I am located in Carpinteria, CA (zip code 93013) and will ship anywhere in US.
  7. I had the same popping noise in two doors. Try spraying white lithium grease, just a small squirt using the little red tube in the spray nozzle, in the door hinges and a little in the door latches. Open and close the doors a few times to work it in. This cured the noise for me. Good luck.
  8. I think I figured out recently what causes the autolock and autounlock features to deprogram themselves in my '07 Edge SE. If the autolock and autounlock features are both "on" and working as they should and I change the Auto Lights headlights off delay (seen as "AL" on the odometer readout) to change the delay time for the headlights to turn off after exiting the vehicle, this action somehow deprograms the autolock and autounlock features. I can't figure it out. Now, however, I have something concrete to show the dealer that something is definitely not right. I discovered this recently and have tried it a few times and sure enough, it deprogams the locking and unlocking features. On my SE you change the headlights delay time by pushing the trip odometer stem that sticks out of the instrument cluster when the car is off and the key is in the Run position. It appears as "AL" followed by 10, 20, 30, 60 seconds etc.
  9. I think I figured out recently what causes the autolock and autounlock features to deprogram themselves in my '07 Edge SE. If the autolock and autounlock features are both "on" and working as they should and I change the Auto Lights headlights off delay (seen as "AL" on the odometer readout) to change the delay time for the headlights to turn off after exiting the vehicle, this action somehow deprograms the autolock and autounlock features. I can't figure it out. Now, however, I have something concrete to show the dealer that something is definitely not right. I discovered this recently and have tried it a few times and sure enough, it deprogams the locking and unlocking features. On my SE you change the headlights delay time by pushing the trip odometer stem that sticks out of the instrument cluster when the car is off and the key is in the Run position. It appears as "AL" followed by 10, 20, 30, 60 seconds etc. Think I'll post this as a new topic.
  10. Has anyone else had a problem with Autolock and Autounlock? It seems the locking system in my '07 Edge will not hold these programs in the memory for more than a few days/weeks and then they deprogram themselves. I've taken it to the Ford dealer four times and they just can't figure it out. Last time they replaced the PCM module per Ford Helpline technicians, as all attempts to locate loose connections failed. They reprogrammed it and it has worked fine for three weeks, until yesterday it stopped working again. I know that I can reprogram it per the owner's manual, but something is not working right in the system. Any ideas out there?
  11. These are brand new Cordura front seat covers made for the 2007 Ford Edge. Extremely durable, they are custom made to fit the contours of each seat. Side airbags are unobstructed for safety. Bottom of seat cover is separate from back and is held in place with adjustable straps under seat. Back of seat cover is held in place by a Velcro closure that prevents any movement or slipping of cover. Head restraint covers are also held in place with the same type of Velcro closure. Large pocket on back of seat covers. These are very snug fitting covers that look totally custom once they are in place. I'm selling these for $150.00. Just decided not to use them. Buyer pays for shipping and insurance. Will accept money order or cashier's check only. I am located in Carpinteria, CA (zip code 93013) and will ship anywhere in US.
  12. Our 07 Edge had the same clicking when we first picked it up. I took it in to the dealer and they replaced the shifter assembly. That took care of the click noise.
  13. Does the MKX have the same fuzzy weatherstrip on the outside of the four side windows as the Edge? I've found that on my Edge these angled fuzzy strips catch everything that blows up against them, from trees etc. Roll the window down while moving and stuff blows in the vehicle. Good old fashioned rubber weatherstrip would have been my choice. I wonder if these could be replaced? Any ideas?
  14. Congratulations to you and your wife. Very wise move cutting back on expenses at this point. Take care.
