wil
About wil
31,436 profile views
wil's Achievements
  1. Hi Will,
    Do you have a copy of the remote start manual (with programming options)?  The links in the original thread do not contain anything.
    Thanks
  2. Hey everyone - looking for an answer online - can't seem to find it. I have a 2010 Edge equipped with Sync (Nav) and I have a "Line In" 3.5mm audio headphone jack and a USB port in the armrest. When I have a flash drive plugged in to the port and something plugged into the headphone jack at the same time - sync does not allow me to choose "Line In". I can only switch between USB and Bluetooth audio. However - as soon as I unplug the USB key - Line In will appear as an option,....... my question is - Is this normal functionality?? Thanks in advance - I hope this hasn't been covered yet - my apologies if it has
  3. I would think its in the same location - under drivers dash - above brake pedal area - you'll see my pic on the first post.
  4. Nvr heard of that happening? Sorry bud that doesn't sound like anything I can help with.
  5. Pffft - "can't be done!" - Scammers!!! Glad to be able to help. Have a great one!
  6. My 2010 edge has sync+Nav and is not a push button start. I've posted a pic of what my button looks like earlier - hope that helps. I also have a single button RMST button in addition to my 4 button key/remote.
  7. Nope - sorry haven't removed the post yet
  8. Shera
    r those mats still available
  9. Hey mike I did not try this on a 2011 with push button start so I have no idea if this will work the same way. I'll edit the post to say 2010 models and lower. If u do try it pls post your results as this may help others and potentilally me . Hopefully I'll be in a 2011 soon!
  10. Hey all i've got a lightly used set of weathertechs for sale. Both front and back floor liners are black and the cargo is beige. I'm in Brampton, Ontario looking for a local pick up. I'm asking for $250.00 for all 3. Let me know.
  11. Sorry for the late reply - just saw your pic. I don't have that located under my steering column - nor am I aware I have that piece altogether. If I do - it's tucked up under my dash. I'm begining to think we have different remote starters. In doing research about turning off this feature - I remember reading that some dealers could have installed a different car starter unit but still used the Ford 1 button key fob (not sureif this is even possible - I just remember reading it). That might be your scenario. My unit was not "factory" installed but it does behave like the steps that are described in the programming - so I'm left to believe it's an OEM unit. Sorry I couldn't be of anymore help - I'm not super familiar with different types of car starters - I had just came across the documentation that is used for OEM Ford starters and wanted to share it. Good luck with trying to turn off that feature - it's really annoying!!! wil
  12. When trying to enter programming mode are u hitting the dark blue button or the black one? The long black wire with a boulbous end and black button seems to me the button u should be pushing to enter programming. I know the button I push is black.
  13. Not too sure - I have the 1 button remote start sytem. Is that the one you have? Maybe try to enter the programming with the door open see if that works. The document states some cars may be set this way. I've tried it on a friends edge and it worked. Granted we both have a 2010 model - not sure if that makes and difference.
