washinml
About washinml
washinml's Achievements
  1. I did fuse it, right at the battery. And you're right I will prolly go back make a hole in the grommet itself just to be safe.
  2. I just ran the power kit for my amp this weekend. There is a big factory hole/grommet that you can use. If you remove the battery, you will see the easiset pass-through ever. It even has a tab on the grommet so you can pull it away from the firewall. That's what I did and then just dropped the power cable through into the inside and down the side to the rear.
