Osiris1975
Everything posted by Osiris1975
It isn't easy to describe without showing you. It'd be easier if you can get the mirror off first. Once the mirror is off, you'll see 5 clips that hold t he colored plastic piece in place. You just push the tip of the screwdriver into the clips to get them to pop them out. The reason I used several screwdrivers originally is because I couldnt figure out how to get the mirror off first. So I used the second screw driver to push the mirror aside while I wiggled the other in to get the clip to pop. It'll be much easier if you get the mirror off first.
I actually figured this out myself. It turned out to be super easy. You just open the door and you will see a plastic/ rubber cover that covers three bolts and the electrical connection for the mirror. Remove the cover, disconnect the electrical, and remove the 3 bolts and the mirror housing comes off. Easiest mirror replacement ever. The only tricky part was that I replaced the colored part of the new mirror housing(which was beige and I picked up on ebay for $100) with my old one, which remained undamaged. There are 5 clips behind the mirror glass that you have to unclip. I did this with great difficulty without removing the mirror glass itself by creatively using several flathead screw drivers. But in the end i was able to pop it off and putting the original color matched one on was easy. Sure beats the $200 plus labor the dealer wanted to charge me.
Anyone have detailed instructions on how to replace a passenger side mirror in the Edge? I am guessing (hoping) it is as simple as removing the A pillar cover to access the 3 bolts and the power cable but I am not sure, and also don't know how to remove the A pillar cover if thats the way to do it. Can anyone please instruct?
So I busted the passenger side mirror on my Edge thanks to a narrow garage opening. Its not too bad, the housing is okay except for the black part that surrounds the mirror (the black portion). I'm thinking I can get any mirror housing and switch the colored part with my current one. Anyone have an experience in trying this? I'll post a pic if my description isn't clear enough. Also, I was thinking of trying to use the 09 or 2010 mirror (I think they have the blind spot mirror which I like). Anyone know if they fit an 08 edge?
Hmm well according to the Pac-Audio site, the PAC MS-FRD1 features include retaining the stearing wheel controls. * Retains all functions of SYNC including: o Voice Recognition Music Search o USB o iPod o Auxiliary Input o Streaming Bluetooth Audio o Bluetooth Phone o Turn-by-Turn Navigation o 911 Assist o Vehicle Health Report * Retains Factory Satellite Radio * Retains Standard, Audiophile, Shaker, THX, and Sony Amplified systems * Retains all Steering Wheel Controls * Retains Rear Seat Entertainment and Rear Seat Controls * Provides all necessary outputs for Standard or Navigation radio installations
I'm seriously looking into doing this. I want to put in an aftermarket nav/headunit, so I called PAC Audio, and they told me that if I wanted to retain steering wheel controls for the music functions I would also have to get this depending on which unit I put in. http://www.pac-audio.com/productDetails.aspx?ProductId=207&CategoryID=29 If you have done this install, can you confirm this? The description for the PAC MS-FRD1 says retains all steering wheel controls but I'm not sure if they mean just the controls related to SYNC.
Thanks...I'm definitely going to put in on the list of things to have serviced next time i take it in.
Was it just the radio for you or the message center and digital a/c display as well? I'd seen others say that their radio went off but none say the other two things.
Okay, this was pretty bizarre. Last week while driving the Edge home from work on a somewhat rainy day, I'm listening to some CD in the car when it just spontaneously shuts off, buttons don't respond, clock goes off. On top of that, the digital AC display turns off completely, as does the message center display in the dash. No amount of button pushing brings it back, but about a minute later everything comes back on. Then, after about 30 seconds, it all goes off again, and comes back on after 15 minutes. It has stayed on since then, but this was seriously bizarre.
So turns out I had the PTO seal problem too, they replaced the seal with the newly designed one. They think the shuddering/vibration while backing up and turning at slow speeds was related to low fluids caused by the PTO leak problem.
Well I will mention it at my service appointment on Friday, have them take a look. I'll post back here on what they say.
Yup, alignment seems fine. I found a TSB regarding 08 edges about power steering fluid leak. Is this something that could happen if the power steering reserve is low?
Welcome to the forums. I got my 08 Edge last week and love it too. Also living in MA in needed something for the winter months.
I don't think so, because it happens even when the wheel is turning a little bit.
Hey there, So I'm one week into owning my Edge and had some observations and questions. I gotta say I love the car so far, and I'm very happy with it, even though I'm having some things serviced this friday. I've got a few questions: 1) Can I put in the stock nav unit that works with Sync into my Edge? Has anyone done so, and if so, can you DIY it? 2) I noticed some shuddering when turning the car at low speeds, like say when backing out of a parking lot? Is this normal? 3) I also noticed that power to the power connections seems to stay on even when the car is off. I plug in a portable GPS and it stays on when I leave the car. I'd prefer it'd turn off automatically, so is there a way to change this? If not, is it likely I could drain my battery by having things plugged in (phone, iPod, GPS)?
Is this type of install fully compatible with Sync and the voice controls?
Hey There, So I want to do my first mod to my new (to me) Ford Edge. I was initially going to put in one of those 3d sherwood kits in a wood finish, but the wife begged me not too, she thinks its too old fashioned. I looked at the carbon fiber but don't really like that either. Anyone know of any other options? I saw that sherwood innovations (http://www.sherwooddash.com/) has satin nickel and brushed aluminum. The stock dash around the stereo/climate controls looks like brushed aluminum already...so I'm thinking of Satin nickel but can't find a good picture to get an idea. Anyone done the satin nickel trim? Anyone done any other kind of trim they like and can post a pic? I already saw the post here (http://www.fordedgeforum.com/index.php?/topic/4357-dash-board-kits/page__p__34235__hl__dash%20trim__fromsearch__1entry34235) But thats not what i'm looking for really. I need something 3d/molded that me and my wife both like. Suggestions welcome.
Yeah, now I gotta go sign another contract at the dealership. Thats going to be awkward to say the least. I hope I won't have to send another complaint to the president lol.
Unfortunately I had already signed the new deal at 4.5% instead of sticking to my guns. So this is what I did instead. I looked up the dealer on the BBB, found out the president's name from their website. I googled his name, found he had a LinkedIn account, as do I. I sent him a message on Linked In. About an hour later they call me back and say the "convinced" the bank to honor the 3.8% rate. The power of the consumer at work.
Thats exactly what I did, I had my own financing set up ahead of time, I just let him convince me he was going to give me 3.8%. You are right though, I should have walked out and just went with my original financing. I just didn't want more delays cause we needed the car for a trip we are taking.
Okay, I have a question, because as I should have anticipated the dealer had another trick up his sleeve. I financed about $10,000 on this car, and the finance guy quoted me a rate of 3.8% over the weekend. Shows me my FICO score yada yada. Tells me that AAA won't honor the rate of 4.09 that they approved me for (I didn't buy that, but I did think he could really get me a better rate). I tell him well are you going to process the application and he says "I don't need to, this is what we call a buyable deal, anyone is going to approve it". So I say okay. I go home and come to pick it the car up yesterday and the finance guy pulls me into his office and says the bank came out with a different credit score, so it puts me a tier lower and now I'm stuck with 4.5%. It comes out to just about $3 a month more but its really the principle of the thing. Heres what I think happened. The finance guy wants to entice me with a low rate, so he pulls my application with the highest of the 3 credit scores from the bureaus. I think they are supposed to use the middle score but I'm not sure. I think he new this but wanted to get me in a position where I'd come when picking up the car and be willing to accept the 4.5% rate. Offcourse the finance guy claims he had no way of knowing that would happen. I don't buy it. What do you guys think? I'm thinking to post a complaint to the BBB, which incidentally, has on record another complaint for deceptive sales practices from this dealership.
Yeah, so I bought a 2008 Limited today, and I am having this problem. Sigh, can't believe I didn't test this out. Still under warranty, but what was the fix for this?
Wouldn't be nice if Ford finally made the Edge hybrid and then you'd get this very cool new feature thats in the 2010 ford hybrids? I applaud Ford, they really seem serious about innovating and winning back some market share. The only thing I'd worry about is looking at this thing when I should be looking at the road hehehe. http://jalopnik.com/5070371/ford-smartgauge-lcd-instrument-panel-brings-futuristic-look-green-leaves-to-2010-hybrids
Yeah wasn't planning on getting the bugshield. I want to put it a wood trim kit, and maybe some ambient lighting in the cup holder and footwells. I want to do it tastefully though, and I don't want the hardware themselves visible at all. I'm thinking to put in a nav system too, but I need to figure out how that can work with the Sync system. For exterior, was thinking of getting chrome door handles at some point, and maybe running boards if getting my kid in and out of the car seat proves difficult. Bumper protector sounds like a good idea, too.
