bender
Everything posted by bender
You should get ahold of Ford Customer Service and tell them of your dealerships resistance to assist you. The leak will be between the rim and bead of the tire. Remove the tire and put soapy water on the wheel where the tire meets the rim, it will bubble. Do each side. When I have trouble with a service manager I take the problem to thier boss and give them a chance to correct the problem. It usually works.
I made a post in another topic about 22s and leaks. In canada Ford has a TSB out to replace any 22" wheels that are leaking, the leaks are due to corrosion around the beads. I had all four wheels replaced by Ford Canada. I can't see why the U.S wouldn't have a similar TSB or I would at least bring it to thier attention about Canadas woes.
Rashing the wheel is very easy. I pulled into KFC and touched the curb putting a little rash on the wheel, I joked that it was a 2000 dollar bucket of chicken. Fortunately my wheels were replaced under the service bulletin. With the tire removed you'll easily see the corrosion on the wheel, I suppose it's the only reason why I would want to use nitrogen in my wheels. It might prevent such corrosion, hopefully Ford has rectified the problem. I know it won't happen to me again, I've traded in the Edge in for a 2012 Ford Taurus Sho.
Yeah, It came in handy for me last year when some bad guys with guns were giving chase, well I drove into the water and evaded them by sucking the air out of the wheels. Sincerely, Bond, James Bond.
Wow, you have no idea what your talking about. Pirelli's are not bad tires nor do they "suck". Ford CANADA has a tsb out on these wheels if they leak, I have had all 4 of my wheels replaced due to corrosion of the finish. I would imagine US Ford would have the same bulletin out.
Sport 22" wheels: can they accomidate ANY snow chain?
bender replied to dg3147's topic in Wheels & Tires
Your sport is a front wheel drive? In Canada they are only all wheel drive. I bought myself a set of 17 studless winter tires and rims for the winter, this thing is like a mountain goat with these; but next step up would be the studdless tire tech with studs. With the 17's you could run the traction products you want. -
I would ditch the grade 2 washers and nut for a spacer and get a plate in there as soon as possible. The frame on the edge is like litmus paper and I wouldn't want to be putting loads from towing into concentrated areas of the frame, you can see your washers are bent from tightening the fasteners already.
I'm a little late here but it was done under warranty, that's both rear wheel bearings within 27 000km and a year and a half. Not confidence inspiiring. I'm told they replaced the right trailing arm also.
Have you had Krown or rustcheck rustproofing done to the vehicle, I had my truck done by one of them and they sprayed thier product onto my rotors. It felt exactly like your describing, I went to the car wash and sprayed them off with soapy water and braking was back to the same way as it was after a few miles of driving, which was lucky; I thought new pads were going to be in order. Tire shine products would also do the same thing if you sprayed them onto the rotors.
It's going back to the dealership next week to get the other rear wheel bearing replaced. It's also getting a checkvalve in the transmission done as well.
I've only got 25 000 km on my Sport and one of the rear wheel bearings is shot, Wtf? This thing has never been on gravel roads and hasn't hit too many potholes I expected more from FORD on quality and reliability. This POS has been in the shop for many months in the year and a half that I've owned it. One problem after another...... Now it's feels like the tranny is losing its drive when accelerating from a stop sign for a second or two, will it never end! Hell my old ford Aerostar with 350.000 km on it only took $400 dollars a year to maintain. Seems as though Ford is going backwards on quality.
I've got a 2010 sport, I think the brakes are good. I can stop it very quickly.
I tried trading it at the dealer, gave them a very reasonable offer. They wouldn't do it, end result is that I've bought a 2011 Sierra Denali; it would have been a Ford truck if they would have been reasonable. I like the Edge, just wish it wouldn't give me grief. I guess it'll get traded at some point before warranty expires if it doesn't become reliable.
I've got a 2010 edge sport, I do like the vehicle but it's been a shop queen. It's had the entire dash ripped out for a hvac smell, the rear lift gate was rubbing on the bumper, this repair took three attempts the final attempt took a new liftgate. Three out of four wheels leak due to corrosion on the beads, they've never seen winter and are stored in a heated and humidity controlled garage. The red lens fell off the right rear taillight, the windshields crack (ford said it was due to rock chips, if it was they were very very small). It had to be flatdecked into the dealership because the ignition switch fuse kept blowing (a burnt wire under the steering wheel column). Then it's been in a bunch of times for the dealer to fix stuff they damaged during repairs. Ford seems to think this is o.k.
Who's selling those rims for $1100. Thats a fantastic deal. EDIT: Nevermind I see you bought them from someone who bought aftermarket wheels. You lucked out. I took my 2010 22" wheel in because it was leaking and the shop stated they're 1800 a piece here in Canada.
I like meguairs m105 followed by m205 then by synthetic 21 and a nice carnuba, like cg pete's 53.
Recommendations for replacement pads and rotors
bender replied to Slurp's topic in Brakes, Chassis & Suspension
I don't know how well this is known but water permiates the oe rubber brake lines and gets absorbed into the fluid, making the boiling point much lower. With SS lines the liners will not allow water to permiate, keeping your fluid drier longer. -
Yeah I'm a dick, I took time out to search and find the instructions; post the pdf file so people can benefit. I guess that makes me a dick. My only obvious fault here was cracking a funny with you.
I can't give you pictures, i didn't buy the ford kit; but you could go to toys r us and buy some crayons to color in the drawerings and imagine they are pictures.
Taken from this site. sk_7t4j_15a416_aa__all1.pdf
They're 22s as well. Thats what I fell for when I seen it on the lot.
I didn't say anything wrong with the function of the lock, I was commenting that one lock and 4 std nuts will not create an unbalance that your going to notice, the extra weight is too close to the center of the wheel to matter. I have a 2010 Edge sport that I purchased on the end of November 2009, I don't think you get free locks with the 10. If someone wants to steal my wheels I guess I'll have to claim it on my insurance, I hope they steal the one with the tiny scratches in it!
1 lock and 4 nuts will not create a unbalance that your going to ever feel. They are simply to close to the center of your wheel to matter.
What about weight reduction and off gasing?
Do I need to add a trans cooler other than the hitch?
bender replied to accent's topic in Cargo, Hauling, Roof Racks & Towing
It's fine to tow with, it's got the trans cooler and with a decent hitch properly installed there should be no issues. The bigger tires and wheels handle the towing with ease. I've only used a class III hidden hitch for a regular Edge, it needed some spacer plates to fit nicely though. Don't go over the 3500 lbs tow capacity, this isn't a truck and the frame certainly isn't designed like a trucks; but if you stay within the recommendations it'll all be good.
