vino125
About vino125
vino125's Achievements
  1. I agree. If the seat bottom were perhaps another 2 inches longer I would have 100% satisfaction with my Edge. To sit better in the seat I do have to tilt the back farther than I would like. At one point I was considering getting rid of my Edge, but I can`t; I just love it too much.
  2. That love will grow ever larger. I love my 07 SEL Plus so much it`s sickening.
  3. I had that exact same thing happen to me once...after I had overfilled the vehicle. At next fill, and thereafter, I stopped filling when the pump stopped. It has never happened again.
  4. I bought mine at Yonge-Steeles Ford at Yonge St. just north of Steeles Ave. Avoid it. The delivery was the worst I`ve ever experienced and follow-up is non-existant. If I had to do it over again, I`d go elsewhere.
  5. These are instructions on how to connect a Sirius receiver, but I do it with an XM Roady2 with no problems. I just sit the antenna in the little box at the end of the console, plug the aux line and the power into the adapters in the armrest box, and set your Edge radio to Aux In (which is after the am/fm/Sirius options). ________________________________________________________________________ BEST - DIRECT WIRED CONNECTION VIA "AUX IN" OR "LINE IN" INPUT for best audio performance and easiest installation. Purchase an audio cable that matches the connection type of your car radio and your SIRIUS radio at your local electronics retailer (your SIRIUS radio requires a 1/8" stereo male connector). Male on both ends. Plug one end of the cable into the "AUDIO OUT" or "LINE OUT" jack on your SIRIUS radio. Plug the other end into your "AUX IN" or "LINE IN" jack on your car radio. Turn the FM transmitter of your SIRIUS radio OFF. ________________________________________________________________________ The cable might run you a few dollars...much cheaper than having Best Buy messing around with your radio
  6. What`s the part number on that, I`d like to get one myself? Thanks
  7. I`m seeing the same thing with my 18 inch wheels (all four). It`s right on the outside edge of the rim, beyond the plastic chrome. As of yet I`ve not brought it up with the dealer, but I might have to if it doesn`t clean off.
  8. It might sound crazy, but I`m lovin my Edge more and more everyday.
  9. I use Esso and my fuel-mileage has been around the 10.8L/100klms based on a avg of 60/40 city to highway.
  10. The total cost was $259.85 plus $15.00 shipping, all US funds. That was for the floorliners and the cargo liner.
  11. When I was in a few weeks ago for my first oil change, I mentioned to the service advisor that my sun shade made noise when it opened and closed. He asked me if it was a rattle or not. Mine isn`t a rattle, so for now I`m leaving it. Apparently to fix the rattle they have to remove the headliner and fix whatever it is that is causing it. He said they have done quite a few in the last while. Maybe what you are hearing is different, but it was a rattle they said was a problem that is happening more and more. Hope it helps.
  12. vino125
    Floorliner/Cargo liner pics
    pics of interior
  13. Check my profile gallery for the pics of the liners. I hope they help you EdgePa...if you need more, let me know. The drivers side pic at the top, you will see that I added a couple same coloured mats. I did that because I like to stretch out once the criuse is on, and I wanted to make sure that all the carpet was protected. The floorliners would be even better if they went about 4-5 inches higher. As for buying them in Canada. Order them online from the US using your nearest UPS Store in the US as the mailing address. Go across when they arrive at the store, put them in, destroy the boxes, mail yourself the paperwork and your good to go. UPS will charge you a slight fee for handling them, but you will still save a lot of money. That`s what I did.
  14. I have the light stone interior and I have both the floorliners and cargo liner in the grey colour. I thought at first that the grey would be too dark and not suit the interior. I quickly got use to it and found that it is actually a nice accent to the light stone. The tan would not work I dont think....the colour is too different to the stone. I`ll try and get a few pics in the next day and let you have a look to see if you like it or not.
  15. I went with a FWD since I have no need for an AWD.
