wtalley
Everything posted by wtalley
My 09 and a friends '10 have both done the same thing. After a recharge, neither have done it again and no problem was ever found.
http.//www.redlinetuning.com
I have the same problem with my 09. I fill up with the dispenser on the first notch, when it clicks off it still takes about 3 gallons to fill it up. The last 3 gallons or so have to be done verrrrry slowly.
They will help, but you will still get some splash on the black plastic lower door panels. If you decide to get the splash guards, drill and install an extra screw in the inside corner of each guard. Mine were flapping in the wind, about to drive me crazy. I installed the extra screws and solved the problem.
Stock turn signal burned
wtalley replied to igcitng's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
The LED bulbs use much less electricity. As a result they produce much less heat. The biggest drawback is that the computer that controls the flasher is fooled into thinking your bulbs are burned out. It flashes faster to alert you to what it sees to be a problem. There has been a post saying the dealer could switch the alert function off. -
Did you read all 5 pages of the post you referenced? Many of us have had the same problem and many have switched to LED bulbs. I'm not saying you have a problem, but after reading about others with burnt sockets, I checked mine and they had already discolored with only 9000 miles. -
We found a better price on an LTD with the lift gate and standard leather than an SEL with the same options.
09 LTD FWD Few little things I would change, but for the most part I LOVE THIS CAR!
I, too removed my filter, drained my oil, preped my new FL400 filter (that my owners manual called for) only to find it was the wrong filter. Being a Sunday, the Ford dealer was closed so I found a Wix to fit at Advance. The only place I've been able to find the FL500 is at the dealer.
2010 Edge Radio Shuts Off Unexpectedly
wtalley replied to smiged21's topic in Audio, Backup, Navigation & SYNC
Mine did that untill I guess it got tired of asking. It said to press the "OK" button if I wanted the report. I found the button and pressed it but never heard or saw a report. -
Mine works great in the concrete parking at work but my wood frame garage at home blocks it out.
We thought we might save money on a new Edge by getting the features we wanted on an SEL. When we got it priced, we found that the Limited was actually less expensive. Whatever you decide, I know you'll love your Edge as much as we do.
Welcome to the forum. It's not alot warmer in TN.
Kind of hard to believe because you really don't see that many on the road in this part of the country, as compared to other CUVs.
I got lucky, one of the local Ford dealers took pity on me and sold me a couple for $8 ea.
I've noticed it many times, not only on my Edge, but on my company car as well. It usually happens on rainy or damp days and when the brakes are applied the second time the grinding is gone.
That sounds like a much better price than what I was offered. Is that price for the full package?
I agree with your assesment of the dash/console, but I would add a complaint about the cupholders. About the only thing that works well is a pop can. I can't find a coffee cup that fits well.
as I remember from the last time I changed the oil in my 09, it was a 15 MM
Jack, hope you love yours as much as I do mine. Love the color. The one we found with the options we wanted turned out to be dark ink blue. We like the color, but living on a gravel road it's a full time job to keep it clean.
