wtalley
About wtalley
wtalley's Achievements
  1. My 09 and a friends '10 have both done the same thing. After a recharge, neither have done it again and no problem was ever found.
  2. wtalley
    Iphone
    Won't come up on my Droid.
  3. I have the same problem with my 09. I fill up with the dispenser on the first notch, when it clicks off it still takes about 3 gallons to fill it up. The last 3 gallons or so have to be done verrrrry slowly.
  4. They will help, but you will still get some splash on the black plastic lower door panels. If you decide to get the splash guards, drill and install an extra screw in the inside corner of each guard. Mine were flapping in the wind, about to drive me crazy. I installed the extra screws and solved the problem.
  5. The LED bulbs use much less electricity. As a result they produce much less heat. The biggest drawback is that the computer that controls the flasher is fooled into thinking your bulbs are burned out. It flashes faster to alert you to what it sees to be a problem. There has been a post saying the dealer could switch the alert function off.
  6. Did you read all 5 pages of the post you referenced? Many of us have had the same problem and many have switched to LED bulbs. I'm not saying you have a problem, but after reading about others with burnt sockets, I checked mine and they had already discolored with only 9000 miles.
  7. We found a better price on an LTD with the lift gate and standard leather than an SEL with the same options.
  8. 09 LTD FWD Few little things I would change, but for the most part I LOVE THIS CAR!
  9. I, too removed my filter, drained my oil, preped my new FL400 filter (that my owners manual called for) only to find it was the wrong filter. Being a Sunday, the Ford dealer was closed so I found a Wix to fit at Advance. The only place I've been able to find the FL500 is at the dealer.
  10. Mine did that untill I guess it got tired of asking. It said to press the "OK" button if I wanted the report. I found the button and pressed it but never heard or saw a report.
  11. Having the memory seat was one of the many things that sold me on the Edge. Now I wish there was a way to disable the annoying thing. It has never worked right.
  12. Mine works great in the concrete parking at work but my wood frame garage at home blocks it out.
  13. Sorry to say, it looks like it's normal. I checked mine at 9000 mi. and they had started to burn. Replaced them with LEDs and solved the problem.
