gwingin
About gwingin
gwingin's Achievements
  1. The I-pod Nano works fine on my motorcycle. :shades: Well I tried to reboot and reconnect using the USB, still the same. I checked the I-pod Nano to make sure it wasn't in repeat before reconecting, and also checked Sync, both were NOT on repeat. After you give voice command to "play all" it works fine, untill you turn the key off, and then back on (back to repeat). Well I solved that problem, I slung the Nano out the window, and connected my I-phone thru USB, now everything is fine. I guess I'm not a fan of the "RED FRUIT" (I'm a PC). Thanks everyone Gwingin
  2. Help I'm having problems with my I-pod in the USB outlet. Every time I turn on the I-pod it's in repeat mode, I have to say play all. After it works fine, but if you turn off the car and start back, back to repeat track. Any help?
