CivicSi907
Everything posted by CivicSi907
So you guys recommend to, simply said, wash the engine with oil till the oil is clean. A few oil changes to clean the engine. I got about 162k on the edge, don't know if the car had an oil change before, because I bought it before 5 years. MOD Edit: Off-topic comments deleted - do a forum search.
I live in Germany.
I have done about 70000km in 5 years. I already added signature on the first time you have said it. I can see my signature on desktop site.
Sorry I don't get it...
Sorry buddy, but I responded to any post you have made. Maybe my English is not the best, but I do my best. I responded with the answer that I have ordered 7 qts of oil. It was meant to be the answer you wanted to have, that I didn't do an oil change for many years. Hope you understand what I mean.
yes!
5w20. Should I do first an oil change and if the error is still there, then replace the solenoids or what first?
And what about the oil? Do I have ordered a good one?
Is it OK to change only bank 2? Is the oil I have ordered ok? Motorcraft Premium Synthetic Blend; SAE 5W-20
I only replaced the camshaft position sensors: Rockauto ok what data exactly? The mechanic shop owner is my cousin, thats because I went to him. I just ordered 7 qts of Motorcraft Premium Synthetic Blend; SAE 5W-20 and a Motorcraft Oil Filter.
Oil change never made since I got the car. Filter also not. I was in a mechanic garage and he could read the error code, but couldn't tell me what's the source of this failure.
Sorry for bumping this old thread, but I am having the same CEL P0020 error on my 07 Edge for about 4 or 5 years now. The car runs smooth all the way. Finally I decided to work on the CEL so it won't come back on again. I already changed the camshaft positions sensors bank 1 and 2. What would you guys do next? Oil change with Motorcraft oil or other recommend oil? Change the Oxygen sensors? What else? Reset and Relearn the VVT? Thanks for any help.
I am still driving with that failure ?
About 160k. Struts/strut mounts nevere replaced. Lower control arms were changed about one year ago. Sway bar links, maybe 2 years ago. What do you mean with plink sound, like a higher frequent sound? It sounds for me like, the spring slips off somewhere. But when I jack up the car, the springt doesnt make any noise and everything looks fine. Should I make a Video of the noise?
Hi guys, I got a problem on my 2007 SEL AWD. I was already at my local mechanic a few times and he can't find where it comes from. It sounds like a metal popping noise and only appears once everytime when coming from a left turn to straigt or when I drive a bumpy road. It sounds for me like its coming from the driver side front wheel area. I also can feel it in the footwell. It only appears in city driving, not on the Autobahn. Everything seems to be tight. Have checked it a few times. Hope you can help me.
2007 AWD Wheel Bearing Torque Specs. and question
CivicSi907 replied to monsterx7's topic in 2007 Edge & MKX
Anyone knows if there is a preassembled front wheel hub assembly with bearing for a 2007 AWD Edge? Thanks! @WWWPerfA_ZN0W maybe you know best?- 2 replies
- cv
- wheel bearing
Can you guys tell me, why my front Bumper is loose where it hits the fender? I can press it back in, but it comes out after some time again. See pictures....
If the "transmission to PTU" seal is faulty, could the PTU be repaired or is the PTU damaged and not reuseable again? Or could it be reused after cleaning and changing all seals and refilling new oil, I think 75w-140, right?
