Depiry
Everything posted by Depiry
Thx like driving an I phone or galaxy 7 edge with the vTech Package all the bells an whistles,great surround sound,electric steering is much easier,gas milage stinks ,dont know what is in tank,and its new,brakes are super ,headlights need some update from halogen,used to zenon on both cars,soon to see Led,, Thanks for your support,Marty
Contact Ford they are unable to do anything at this time. i have the new car!!
No dealer did not pursue after warranty adjustment, THX
Had a 2010 Edge Limited AWD with 64039 miles,the other day the car startded missing and check engine light came on,started stalling, battery went dead and installed new one,made appointment with dealer,had car towed back to house,car restarted but had slight miss, at dealer they scanned car,got a call to come in for explaination, cam and crank sensors out of alignment ,timing chain jumped,water pump leakink,possible bent valve, was told car needs engine,warranty expired in august, Cost to replace $7000.00 traded for a 2016 Titanium Marty
stainless means what it says unless you have 314 which is bullet proof, Had a boat and the rails would rust and that was explained to me. barkeepers friend is a good cleaner polish ,use it with a scrubber sponge, steel wool leaves metal that will rust on the stainless tips, Marty
Water Spots Removal
Depiry replied to t0lkman's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Cerium Oxide , Marty -
Shock and Struts: help needed with parts choice
Depiry replied to Wiktor Rawdanowicz's topic in Brakes, Chassis & Suspension
An account of mine had 221 ford escape Hybrids as NYC Taxis,which he got 400,00 miles plus and I asked him to get me shocks and struts he recommended OEM as the aftermarket did not last as long as OE. he got Me OE, for my 2010 Edge,Marty -
Exide Edge AGM has a 4 year unconditional guarantee plus free jump starts, Marty
2010 5.5 Qts
HID Start Up Time question.
Depiry replied to chipworkz's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
The HID bulbs are basically Metal-halide lamps all Hid or,gas discharge lamps take some time to come to full brightness after the arc strikes. Marty -
How do I wire in power inverter?
Depiry replied to jjones0377's topic in Accessories & Modifications
A 400 watt inverter will draw about 33.33 amps at fulloutput it needs at least 30 amp relay,and fuse off the battery if you dont intend to use it at full output, as the wizard says thats your best hook up, a Bosch relay rated at 30 amps should work well,Marty -
Use only the approved antifreeze by color
Check owners Manual : LV for trans V for power steering Not the same 2010 imited Marty
In 1996, we developed the FIRST consumer product for repairing paint chips, scratches or even ROAD RASH for cars, boats and planes! It's so simple to do, even a child can do this repair! The Blob Eliminator, our original product will even remove tar, tree sap and other paint surface contaminants. The BLOB ELIMINATOR works with ALL touch up paints AND is the ONLY consumer product that works with your MANUFACTURERS TOUCH UP PAINT, the preferred touch up paint for many reasons.
Anyone try Langka Paint chip Repair??
Ford Edge (unrefined powertrain ... ride is jittery and road noise invades the cabin. And the MyFord Touch system is convoluted to use)
In the states that sell chevron gas with techron the rental cars always run better after 1 tank full, I had and Audi 5000s that i only ran premium in after speaking to another owner that said it calls for regular,I switched and found cold weather starts much faster than with the premium, Marty
I use Vallero,Mobil ,Getty,BP, None ar top tier and have the additives to really clean, Marty
2010 Edge Limited; I Have a similar noise changes as trans shifts and only occurs below 32 Deg
I have a 2010 limited,it was running a little rough idling,just used Techron Injector cleaner and it's like new ,Just my 2 cents,Marty
Welcome Todd, along with te items posted by WWWPerfA_ZN0W, What is the capacity of the ptu, and is the fill plug on the passenger side of the case, also: almost impossible to access, is the drain plug on the lower case near the trans drain plug,both tje same size, thanks Marty
I just installed an Exide 36 RC 650 CCA,oe was 540 cca same size, Marty 2010 Edge
I just installed a 2010 proto type of the led tail lamp ,the construction quality is like OEM,the install is less than 10 minutes,the light given off is much greater than OE,the look and effect of the led's is very dramatic and enhances the the look of the vehicle,much greater visibility over the recessed bulb,the turn signal has gresater visibilty ant the whole item gets a great thumbs up from me,Marty
- 58 replies
- LED taillight
- LED tail
- (and 8 more)
