Depiry
About Depiry
1,174 profile views
Depiry's Achievements
  1. Thx like driving an I phone or galaxy 7 edge with the vTech Package all the bells an whistles,great surround sound,electric steering is much easier,gas milage stinks ,dont know what is in tank,and its new,brakes are super ,headlights need some update from halogen,used to zenon on both cars,soon to see Led,, Thanks for your support,Marty
  2. Contact Ford they are unable to do anything at this time. i have the new car!!
  3. No dealer did not pursue after warranty adjustment, THX
  4. Had a 2010 Edge Limited AWD with 64039 miles,the other day the car startded missing and check engine light came on,started stalling, battery went dead and installed new one,made appointment with dealer,had car towed back to house,car restarted but had slight miss, at dealer they scanned car,got a call to come in for explaination, cam and crank sensors out of alignment ,timing chain jumped,water pump leakink,possible bent valve, was told car needs engine,warranty expired in august, Cost to replace $7000.00 traded for a 2016 Titanium Marty
  5. stainless means what it says unless you have 314 which is bullet proof, Had a boat and the rails would rust and that was explained to me. barkeepers friend is a good cleaner polish ,use it with a scrubber sponge, steel wool leaves metal that will rust on the stainless tips, Marty
  6. An account of mine had 221 ford escape Hybrids as NYC Taxis,which he got 400,00 miles plus and I asked him to get me shocks and struts he recommended OEM as the aftermarket did not last as long as OE. he got Me OE, for my 2010 Edge,Marty
  7. Exide Edge AGM has a 4 year unconditional guarantee plus free jump starts, Marty
  8. The HID bulbs are basically Metal-halide lamps all Hid or,gas discharge lamps take some time to come to full brightness after the arc strikes. Marty
  9. A 400 watt inverter will draw about 33.33 amps at fulloutput it needs at least 30 amp relay,and fuse off the battery if you dont intend to use it at full output, as the wizard says thats your best hook up, a Bosch relay rated at 30 amps should work well,Marty
  10. Use only the approved antifreeze by color
  11. Check owners Manual : LV for trans V for power steering Not the same 2010 imited Marty
  12. In 1996, we developed the FIRST consumer product for repairing paint chips, scratches or even ROAD RASH for cars, boats and planes! It's so simple to do, even a child can do this repair! The Blob Eliminator, our original product will even remove tar, tree sap and other paint surface contaminants. The BLOB ELIMINATOR works with ALL touch up paints AND is the ONLY consumer product that works with your MANUFACTURERS TOUCH UP PAINT, the preferred touch up paint for many reasons.
  13. Anyone try Langka Paint chip Repair??
