Brandon Paul
About Brandon Paul
Brandon Paul's Achievements
  1. Hello there buddy..What specific ford parts do you need? So that whenever I find a new one, I can post it here right away...
  2. Hello Sir..It has been a pleasure to meet you. Just want to ask you on where you actually get the ford parts you sell? I am just curious about it.
  3. Hello Sir..It has been a pleasure to meet you. Just want to ask you on where you actually get the ford parts you sell? I am just curious about it.
  4. Hello there buddy! Thanks for the list of ford parts. The numbers really helped me and my cousin figure out what front brake rotors to buy. Thanks a lot..
  5. Hello there buddies...Hope you can help me with this one.. Do you know where I can buy an Oil Galley Screen Kit? I really need the kit badly for my engine..Thanks a lot guys..
  6. Hello there! I have a problem with my rocker arms. There seems to be missing bolts and nuts. Do you know where can I buy a Rocker Arm Nut Kit with the cheapest price? Thanks!
  7. Well I am glad you've already installed the headlights. Regarding the issue on the effects of the headlight replacement, this would not really affect other parts like the Alternator. Just be careful with your installation whenever you encounter problems as such.
  8. Hey there..You know what, I think the best thing you should do is to check your Thermostat settings. From there you can figure out what is wrong.
  9. Well, removing the bumper is a no easy task. You should read some articles on how to change bumper bracket or side support. It will give you knowledge on how to remove your bumpers safely and the right way before you make any repairs on some other parts of your car.
  10. That is not normal man! The car is only 6 months old and it is already encountering those kinda of problems. i think the dealer should replace the entire car man. Just a tip when buying cars. Check each and every part of the car, especially the engine parts. Check even the smallest detail like the bolts for example. Check if there is no missing Differential Cover Bolt. Sometimes when the differential cover looses its bolts, noise builds up when stepping at the gas.
  11. It is the valves that caused the problem. Is it still under the warranty? The car dealer should be responsible for that one. They should replace the truck parts if it is still under the warranty.
  12. It could be either an electrical problem or an engine problem. Check your electrical wirings coz these wires could be the cause of the electrical glitch. Next, also check your Performance Pulleys if they are working properly. Sometimes the pulleys are the cause of these problems.
