tamgc2
Everything posted by tamgc2
  1. took off from stop sign in heavy traffic, all of a sudden i hear a hiss of air and immediately think i just blew a tire, not the case, as i continue i hear a whoosing of air from in front of the passenger side as i am accelerating. once i hit high gear it stops, but if i apply the gas it begins again until i let up and car is no longer accelerating. investigating i am drawn to the conclusion that it is the blow off valve. any thoughts, if it is bov where is it located on 2019 edge?
  2. alright, so its lane changing, never had awd so i kept looking at awd symptoms and solutions, i found it turned it off will drive tomorrow to see what happens technology is killing/saving me if you ever need help with a 73-79 f100 let me know, simplicity is awesome thanks for the help could not have done it without your insight
  3. ran obd2 no saved issues no pending issues, did read that grinding chattering in slow turns could mean need to reprogram awd module, so far thats all i could find. updated the auto updates just to be sure i havent missed anything. at this point still at a loss
  4. yes its side to side never has it indicated front or rear, one side is red while the other side is usually green
  5. none of those things happen, only when driving. i watch as the light indicating each wheel lights up with a different color, red on one side while green or chartruese on the other. i am driving on drive paved road no weather conditions that would impact my driving, no rain no wet pavement. at 76 i have done a lot of long hiway driving as well as local streets there is not much i havent experienced. it does seem that if i give it the gas in a situation where it would start applying traction control it just shows green or no color, thes would be situations in which you are doing the opposite of would you should in that instance,
  6. i have a used 2019 edge, 46,000 miles. the traction control is very strong and if you dont have both hands on the wheel its breaking action, when changing lanes, can pull you into oncoming traffic, the off/on button does not seem to work as it continues when the indicator says it is off. there was a brief period of about 4 weeks when it did not work at all. very comfortable driving during that period. i did not do anything to create that situation. then for some reason it starts working again. not sure what to make of it. i did have head gasket replaced 2 months ago, not sure if that had any connection but do not remember having an issue before that, could have and just dont remember as i only had car for 3 weeks at that point. any thoughts. saw where traction control module, if it is a plug in unit can be replaced fairly easily
