07CRUSH
About 07CRUSH
07CRUSH's Achievements
  1. This should be what you are looking for 2008-12-30_042008_base.pdf
  2. Does it repel radar , LOOKS SWEET
  3. In the cargo area , remove the spare tire cover and the left side cargo divider and u will see a module.
  4. In the cargo area , remove the spare tire cover and the left side cargo divider and u will see a module.
  5. It's goes under the little tray(the half moon) on your dash,
  6. Before you go spending your money .This mirror is heated, look below the blind spot mirror and you will see a little square with lines that tells you have heated mirrors.Look at your mirror
  7. No they won't work , you need the valve stem type.
  8. From the 2007 up to 2010 the bumpers are the same.
  9. They never came with built in ashtrays ,you could order a smokers package that included a cupholder ashtray and lighter like this
  10. There are 4 bolts to remove the headlamp , before you do that you have to take the fascia off.
  11. I had a 2007 sel fwd and drove it like you did and not a problem.
