Todd Turner
About Todd Turner
Todd Turner's Achievements
  • First Post Rare
Recent Badges
  1. Weird issues with brakes on 2013 Ford Edge. started with no brake pedal. Old school thought master cylinder, also had booster leak so both replaced. More troubleshooting found ABS module bad. Now after driving for about 30min feels like front left wheel locks up and have to turn vehicle off 5 min it releases and is fine for the rest of the hour trip. on the way home an hour in happens again get code Code: C0044 - Brake Pressure Sensor 'A' Additional Fault Symptom (:28): - Signal Bias Level Out Of Range/Zero Adjustment Failure Status (-68): - Previously Set DTC - Not Present at Time of Request - Malfunction Indicator Lamp is Off for this DTC - Test not complete Module: Antilock braking system Freeze Frame #1: -EVENT_TIME: 377763044 s (Wed Apr 02 16:44:58 2025) - Event time -POWER_MODE: Running - Power Mode Status -ABS: Inactive - ABS -AYC: Inactive - AYC -BTCS: Inactive - BTCS -201D -HDC: Inactive - HDC -RSC: Inactive - RSC -BTC: Inactive - BTC -VAC_BST_ST: Inactive - Active Vacuum Booster State -BST_REL_SW: Inactive - Booster Release Switch State -HYD_PMP_ST: Inactive - Hydraulic Pump State -ECU_POWER_SUPPLY: 13.5 V - ECU Power Supply Voltage -VSS: 5.6 mph - Vehicle Speed also Code: P193C - Steering Wheel Angle Signal Status (-6C): - DTC Maturing - Intermittent at Time of Request - Malfunction Indicator Lamp is Off for this DTC - Test not complete Module: Powertrain Control Module did the PCM key on engine off on demand self-test and PCM Key ON Engine running tests it didn't find any faults. I see in list it says GO to Pinpoint Test C. Can you provide? About to just sell this thing to lowest bidder lol this has been so frustrating. .
