mdk1016
About mdk1016
mdk1016's Achievements
  1. Interesting. So No torque specs on that one? Where #4 is the nut on the end that holds the control arm, just on the other side of that end of the control arm there is a little bolt there. I'm honestly not sure what it does. It just has a large washer and doesn't hold anything together lol. Guess it's not as important to have torqued to spec so I will just tightening it a good bit to what feels right for a 12 or 13mm bolt. Thanks again Haz! Its insane how hard it is to find this illustration. Even searching part number torque specs still wasn't giving me the answers I needed but you got them same day I posted. I really appreciate it!
  2. Thanks for the information Haz! Great stuff. Will be nice to have for future work with all the info! Do you happen to know which one is the small bolt on the lower control arm? I'm assuming the nut on the outside is the outboard nut for the lower control arm to secure the lower control arm to the knuckle. There's another smaller bolt with a giant washer. If I recall I think this bolt was only a 12mm or 13mm bolt. I feel I'll break it if I try to to torque it to 111 ft lb which is the only other number I see on the lower control arm. I'm not entirely sure if it is the cam adjustment bolt or not. I loosened it by mistake before I realized I didn't need to take it off.
  3. Hello all. Never had so much trouble trying to find torque specs like this lol. Hoping someone can help me out here. I have a 2011 Ford Edge AWD with the 3.5l motor. I am looking for the following torque specs for the knuckle and hub assembly area. Shock Absorber Lower Bolt to the knuckle: Hub Assembly: Lower Control Arm Nut and the smaller bolt that connect the knuckle: Upper Control Arm to the knuckle: Lateral Arm to the knuckle: Trailing Arm for the four bolts to the knuckle: Axle nut:
