As always, use the information below at your own risk. Always back up your setting before making modifications.
I wanted to provide an update to this post to cover 2021+ Ford Edges. The Forscan programming portion has changed since the earlier year vehicles. The heated steering wheel master enable has been moved from the FCIM module to the HVAC module. It appears that the FCIM module no longer exists in the newer vehicles.
The connector for the heated steering wheel control module is located behind one of the supports that you can access by popping the fuse cover off to the left of the steering wheel.
Below are the following values set to enable the heated steering wheel, add it to the touchscreen display and set the temperature to 92 degrees. Note, these settings are for a 2021 ST Line.
Note, if the values are used other than the ones the above, the checksum of the entry will need to be recalculated. The underlined values are the ones that were modified for each setting. All other parameters in the message were unchanged (unless the CRC needs update). Note those settings could vary based on the model and options in your vehicle.
For detailed breakdown of the options, refer to the spreadsheet in this post.
https://www.f150forum.com/f118/forscan-software-enable-disable-features-your-truck-348987/index754/
Module
Memory Address and Value
Description
HVAC
733-01-01 5a19 e561 80F5
Master Enable HSW
APIM
7D0-02-01 0402 5e8a 07CF
Enables button on touchscreen
IPC
720-02-02 1D01 FD46
Turns on HSW when remote start
HSWM
714-02-01: 025C 5C5C 34
Wheel Temperature = 92ºF - 2016/2017/2018 Fusion Default
Link to checksum calculator.
https://www.ford-trucks.com/forums/1706860-forscan-check-sum-excel-spreadsheet.html
