doggie
Everything posted by doggie
  1. If you have electronics soldering knowledge, then this is an easy repair.. you have to find the part for the burn transistor inside PCM. It cost like 0.80$. Unplug battery, take 2 bolts out of PCM. Take PCM out replace transistor.. 5mn. Reassemble pcm. Replace damaged/burn ignition coil $40. should not take more than 30mn.. had to research this online.. you would not need re-programming or PATS resetting for keys because all configuration are intact .. a dealer will charge you 2500$ for a brand new PCM and reprograming..
