Jarekmucha
About Jarekmucha
Jarekmucha's Achievements
  1. Thank you for your HELP. I managed to solve the problem thanks to your tips and diagrams. The problem was very trivial... The c900 connector turned out to be the culprit. More precisely, I had the headliner removed which interrupted the MS-CAN bus THANK YOU !
  2. can someone send the diagram of the connector to the gateway module?
  3. I have Forscan and an OBD adapter VLinker F5, IT READS THE MS AND HS BUS. The problem is the lack of voltage on the MS bus section. I have information that the beginning of the bus is in the gateway module
  4. Yes. Vgate. forscan sees the MS bus. but only the side of the ms bus where the voltage is 1.7V
  5. Hello, I have a problem with the MS CAN bus, namely it does not detect forscan SODL, DDM, HSWM and RGTM, SODR is detected. The voltage at the cube between pin 5 and 8 is 12V, on MS CAN 6 and 7 none, and on the working SODR about 1.7V Where do these trunk lines meet?
