Corjayedge
About Corjayedge
Corjayedge's Achievements
  1. I am having an on going issue with my 2013 ford edge. I went through 3 pairs of tire bc the rear tires have excessive negative camber. I changed the rear lateral control arms and thought that did the trick. Did not make a positive impact besides having the seized bolts replaced. There are 4 cam adjustment bolts 2 on the lateral control arm and 2 on the Mood cam adjusters. I need to changed the 2 on the control arms it looks like. Thanks for the tip! If there is anything else I should know, also my 2013 edge limited has just hit 200k, 😃 3500k oil changes and no water pump issues 🫡
