PatrickGuinalia
Everything posted by PatrickGuinalia
Hello! The bulbs are of the normal model, the common type. None of the turn signal bulbs are LED. But I can try to exchange them for new ones of the same model to eliminate the doubt, however they are in good condition and blinking normally. in the front, rear and in the rearview mirrors they are ok.
Hello! I have a problem with the turn signals. They flash like crazy. Sometimes they stay on, sometimes they stay off, sometimes they are lagging, both sides. But the lights on the outside of the car continue to flash at a normal rate, without any errors. All the bulbs are ok. Sync2 reset ok. No codes on ForScan. In the video you can see the lights flashing normally on the outside, and in the cluster the turn signal gets stuck sometimes. This happens on either side. And if I use the alert , when the lag happens, it happens on both sides simultaneously. If one stuck on, the other too. The “turn sound” (that “clicks”) follows the cluster, when the green arrow lag, the sound lags too. Any idea what this could be?
ABS,Brake, Stability Control warning lights on
PatrickGuinalia replied to hilokamper's topic in Brakes, Chassis & Suspension
Hello friend! I tested all the ABS wheel speed sensors and they are correct, no sudden changes even with the warning lights on. Test: The code U0415 seems to only appear when I disable ABS, traction type and traction control in the FORScan. If I enable the options normally, it disappears and only P193C and U3000-49 remain. Maybe U0415 it's just a warning of incorrect panel configuration. Is there a test for the steering angle sensor, before definitively condemning the ABS module for repair? -
Hey guys! Also reactivating the topic, I had the same problem on my Edge AWD 2014 3.5. The car was off, I simply turned it on and the parking brake, ABS, traction control and stability control lights were on, accompanied by two warnings on the left screen of the dashboard: check brake system and advancetrac service. (picture 1) The codes shown on the forscan were P193C and U3000-49. (picture 2) When searching here on the forum and also in various videos on the internet, many people recommend replacing some internal components of the ABS module. However, sometimes this warning does not occur, and no warning light comes on on the dashboard, which appears to be an intermittent error. So I'm still unsure whether to disassemble the part and send it for repair, as it's a very expensive service and I'm afraid it won't be resolved. Yesterday I disabled the AdvaceTrac, ABS and TCS options in forscan, and the error message on the left screen 'check brake system' does not appear. In this case, with these lights deactivated, another code showed on the panel: U0415:56-2F. After researching, he led me to a person who discovered a problem with one of the ABS sensors on the wheels. (picture 3) Now I'm in doubt as to what the reason for the problem would be, because the mechanic recommended replacing the abs module, but I have three codes: P193C and U3000 together, and when these are erased and their indications are turned off in the forscan, U0415 appears. The car's brakes work normally, when traveling or in urban traffic, no problems when using the brake pedal, no strange noises or anything like that, everything is normal with or without the warning lights. -
PatrickGuinalia replied to ben senise's topic in Accessories & Modifications
Thanks for getting back to me friend! In this case, it becomes something more complex and risky, so I prefer to end the search for climate control here. Anyway, thanks for the help so far! -
Unfortunately the code does not work for the right screen of the panel, but enabling or disabling the climate control menu in Sync2. -
Heey! A good new code hahah I'll try it in some hours and come back here! Other things that I'm trying to enable and the options in this topic and another videos don't work: - TPMS graph in left screen - Digital speedometer in left screen But the priority is the climate control, it'll be so cool and safe! The center console buttons aren't that useful because you don't have haptic feedback and you have to take your eyes off the road to use them, which ends up being dangerous. -
Hey dude! Climate buttons in Sync is ok, I just have them 720-05-01 is what I want! I had already read it here in the topic, but in my Forscan in this option of codes I just have until 720-04…… 720-05 doesn’t exists! How can I find it? -
This option doesn’t exists here 🫤 do you know a different way to enable it in Ford Edge 2014? -
I tested it here on the Edge 2014 Limited and it worked. There was a conflict with the internal colored lights: it was not possible to turn them off or change the color. But I just had to start the car with the engine running and everything went back to normal. Thanks! -
It worked here in Ford Edge 2014 Limited! I chose A for 5 flashes. Thank you! -
Hello friends, I bought my Edge 2014 3.5 AWD Limited just over a month ago and today I read all the pages here in this topic. However, I didn't find any option that works to enable climate control with ForScan on the right screen. Is there such a possibility, or only on Edges 2015+?
