update on transmission problem with those codes P0657 and P0742. the cable harness going from PCM to Transmission was bad. on the transmission shift module main plug was checked out 3x by doing a continuity test and all was good but when plugged in transmission connector if you wigged that plug i now can hear the transmission shift solenoids actuate. Problem solved and i got that new harness from the dealer for 275.00 and took 6 hours to remove and replace. I waited a month driving car and problem is gone. I wiggled the new connector/harness at same area, and all is good. Finally, this very intermittent problem is gone.
