Gotta strange one, 2019 Titanium 2.0 temp gauge the last few days seem to flutter up and down doesn't over heat heater works great fluid level good radiator cap seems in good shape but the gauge bouncing up and down maybe a gauge sender unit issue
TIA
I just pulled out of a parking lot, no towing at all, doing about 30mph down the street, disable message came on, drove another few minutes stopped for traffic lite then the restored message popped up. Not really sure what have caused this
Had a message pop this morning "AWD temporarily disabled" then about 5 minutes later displayed AWD restored what would trigger this ? 2019 edge Titanium can these sub zero temps we've been having cause this.
TIA
Yes I've had that message pop on my sync screen a couple of times. No problems with starting in our current sub zero weather here battery seems to crank over no problem. Going in for oil change service this coming week going to have them test battery. I always turn off the start/stop with the switch by the park barke.
Hello. We have a 2019 edge Titanium when using the intelligent Access to unlock doors is this suppose to work on a door handle or just the drivers side door ? At the moment ares seems to only work on the drivers side door handle.
TIA
Mike
With recent high humidity & dewpoints in the early pre-dawn hours been have a real issue with the windshield constantly fogging up on the outside, not the inside. Other then using wipers and defroster is then any tips or tricks to cut down on the fogging up on the outside of windshield
TIA
Mike
Hey thanks appreciate the info. I've also heard some stores security camers can also screw your cars signal too. I'll try your suggestion next time.
Thanks
Mike
Hello got a strange problem with our power liftgate. This only happens when parked at our local Walmart. The liftgate opens fine but doesn't want to close with remote button, dash button or button on liftgate. If hit the button a few times it does finally come down. No where else does happen just at the walmart parking lot. Any suggestion what to check. Also there are no obstruction that would cause the liftgate not to close
TIA
Mike
