09EdgeSEL
Everything posted by 09EdgeSEL
  1. Problem solved. It was the crank position sensor.
  2. Hopefully someone has had a similar issue and will chime in at some point. Thank you
  3. I have the Ancel AD310 Classic Enhanced Universal OBD II Scanner. That was my thought on the crank position sensor as well.
  4. I scanned it and didn’t get any codes. Also the tach stays at 0 when cranking. Someone just suggested the crank position sensor.
  5. Also the tach stays at 0 when cranking. Someone just suggested the crank position sensor.
  6. 2009 Edge 3.5L Cranks no start (189,000 miles) I’m struggling with diagnosing my issue as it’s been quite a few years since working on a vehicle. I’m getting spark because when I spray in starting fluid it runs perfect. I can hear the fuel pump and saw gas pump out when I disconnected the line from the rail. All that’s seems to be left is figuring out why the injectors aren’t spraying fuel into the cylinders... Is there something that would stop all the injectors from working at the same time? A sensor or switch? Any help would be greatly appreciated.
