Hello. I have a 2013 Edge Limited AWD and I’m going to replace the ABS module due to the sticky bypass valve issue.
I understand I will need to program it, and that the traditional way to do that is with a VCM and Ford IDS. It would seem however that VCM units are all but unavailable.
I can find plenty of info that J2534 with FRDS will work for 2018+, and some info that J2534 with FJDS will communicate with the older units like mine, but no confirmation that I would be able to use J2534 to program the new ABS/HCU module.
I have the engine/trans assy out currently due to water pump and other maintenance, I figure I’ll change out the brake system items (hcu, booster) while I’m here.
Can someone point me to a scan tool I should buy to do this? Will FJDS and a unit such as the Mongoose Plus or the CarDAQ Plus-3 program my new unit?
Thanks
