WoodGood
Everything posted by WoodGood
  1. I'm just using factory plugs, but how did you even pull the coils with that tube resting on top of them. I can't seem to move the tube forwards or backwards more than about 1" and can't move it up any more than about 1/2". I can't even get my hands around the coil to pull it ??? Did you just pry the tube forcefully in a direction you needed. I'm worried about breaking the joint down at the turbo if I do that.
  2. 2019 Ford Edge ST Tried to get to back 3 plugs (cyl's 1, 2 and 3 - transverse engine), but can't even get close due to turbo inlet tube. Tube totally covers both plugs. #1 cylinder is barely doable with loosening all the mounting bolts (top side) on inlet tube. Seems like the turbo inlet tube needs to be detached down below at the turbo. Tried to go in through the passenger side wheel well with liner removed but could even see it. Suggestions please if anyone has done this.
