Everything posted by GTEyes
Good Evening, I noticed tonight one of my fog lights is aimed lower than the other. Looking to aim them. I presume there is a hex adjustment on the bottom but before I get under there wondering if there is a procedure? Looking on Ebay at the foglight parts, there seems to be an adjustment screw. I presume I will need to remove the splash shield as well? Has anyone aimed their fog lights before? Thanks for the help!
A surprisingly easy process.
It definitely is that bar...when I push on it, it makes the hollow tick noise. I had a piece of velcro under the little spring arm that pushes against the bar for awhile and it didn't seem to help. I might take a more aggressive approach next fix attempt now that the dealer isn't going to do anything. I kept it all closed up for a month as we moved into winter and not using it seemed to let it settle and the ticking stopped. Had the dealer look at it a few weeks ago and they didn't see any issues. Now that it's been opened and poked at it's doing it again..so trying to keep it closed (including shade)to see if that helps again. Excited that we have some keeners in this discussion that want to try and troubleshoot and problem solve.
This and the other info. provided by others has been so helpful. Thank you!
To add some credence to what's being said by most, the seats are still identified as "Cooled" on the Ford build and price website, so I am going to assume the TED is still being utilized.
Can someone that lives in a cold climate (close to freezing) please try this? After a cold start, turn the ventilated seats on and observe their behaviour for a minute or two...see if the fans start to cycle on/off on their own.
Dealer wasn't able to replicate so no fix as no issue was observed (the fans stayed constant). No error faults were found in the system. Just looking at all the information versus what's in Ford's workshop manual (Thanks again, @Haz), there is conflicting information. Ford is saying the TED is still used but as people have pulled the seats apart, they are only seeing fans...and the heating function definitely does not use these seat fans, from my own observations. Maybe the SMCE is still monitoring temps and that's why it's changing one of the fan's speed...I have no idea. The heating function definitely does not use the blowers, so Ford's literature is outdated on that from what I can tell, which means any Ford Technician referencing that is being led astray. Sounds like I will just have to live with it.
Software update or something?
GTEyes replied to Brockdog12's topic in Audio, Backup, Navigation & SYNC
My '24 did an update last night. The Sync system is quite different now...has different icons and a bunch of settings were changed to the defaults. -
Can someone with the ventilated seats try turning them on after a cold start in a climate that is close to freezing to see if their seats do the same thing? I suspect the behaviour is normal.
Another update. Both the seats do this...driver and passenger. Sounds like there is a fan in the back cushion that is also turning off and on...I thought only the bottom cushion was ventilated? Service appointment at the end of the month so we will see what they say.
Adding this to my next service appointment. Here's a video of the seat fan surging. Anyone ever see or hear this occur on their vehicles? IMG_0501.avi
A little more on this issue. Noticed this morning that the fans for the ventilated seats were surging (making more then less noise). Sounds like something is going on with the part. I will have to get it looked at next service.
My Ford Touch New Software Release
GTEyes replied to tjbron's topic in Audio, Backup, Navigation & SYNC
This seems to be the thread to ask the question... I am noticing there's a new version of Sync available for my 2024 Edge but it hasn't been pushed out yet by Ford. Curious is anyone has seen an over the air update to the version noted below? -
Update. Swapped the tires and took the Edge for a drive. All 2019 sensors paired and updated on their own once I got over ~80 km/hr.
Update on this. No hood fluttering now that I've raised up the hood bumpers. Had my first service yesterday and checked the other Edges on the dealer's lot and they all have this driver side issue where the grill trim is not flush and sits farther back than the passenger side and the hood also seems to sit higher on that side. I am going to live with it as is.
We shall see. Be fun to do a swap some weekend and see what happens! Thanks for replying and sharing your experience
Hi folks, Picked up some winter rims/tires for a good price and they are off a 2019 Edge. They have TPMS sensors on them and I am going to do a dry run with them sometime soon to get them setup and ensure they work. My previous Mazdas were simply install and they worked. I have a few questions. 1) Will the 2019 sensors work with my '24? I am seeing two frequencies when search ford part numbers online. It's not clear to me if the '19's will work with my system. 2) Is there an official process to get these new sensors working with my system or is it an install and drive situation? Ideally, i don't want to buy any tools but I supposed I will have to if need be. I am seeing info. on here that the Ford TPMS is different and that I may need to do a "relearn" procedure and that it can be done via start button pushes, etc... found a Youtube I would appreciate any advice! Thanks,
I started it remotely two days in a row and no noise. I will monitor.
Hi folks, Heard a noise on the weekend when doing a remote start on my '24 ST...didn't think anything of it, thought I was hearing things, turns out I was! Then this morning, I see a post on a Facebook group of someone else's doing the same thing. The video in this post is the noise, https://www.facebook.com/reel/437474385816105?fs=e&s=TIeQ9V&mibextid=3pERcX Anyone else hear this and know if it's typical behaviour?
