GTSnake
About GTSnake
GTSnake's Achievements
  1. Wow, that's the cheapest I've seen. The lowest I've found outside of Rock auto was $8/qt.
  2. 23k miles and you need tires??? Those tires must be really soft or you're doing road ralleys on the weekends. I was looking into tires for my ST and found these with 80k mile warranty. https://www.tirerack.com/tires/tires.jsp?tireMake=Bridgestone&tireModel=Alenza+AS+Ultra&partnum=64VR1AASUXL&vehicleSearch=true&fromCompare1=yes&autoMake=Ford&autoYear=2019&autoModel=Edge ST AWD&autoModClar=Performance Brake Package The P zeros are on sale right now but there's only a few left. https://www.tirerack.com/tires/tires.jsp?tireMake=Pirelli&tireModel=P+Zero&partnum=64YR1P0XLOS&vehicleSearch=true&fromCompare1=yes&autoMake=Ford&autoYear=2019&autoModel=Edge ST AWD&autoModClar=Performance Brake Package
  3. I think they skipped a step in the reprocessing of ocean plastics. They said it's washed then extruded. You can't extrude hard plastics it has to be melted first then extruded. But the surprising thing is how much effort and energy is spent in gathering and processing this waste material and still comes out cheaper than making new.
  4. You're asking to retrofit a larger screen into a vehicle that was never designed with it in the first place. You would need to develop completely new software since the infotainment is integrated into so many systems such as engine, climate, seating etc. Then you would need to make space for it so you would need to relocate other systems in place. So the short answer is Yes but you would need to do a LOT of work.
  5. Yes, this threw me for a loop too. I thought it didn't work because there's a delay when the car is programming the new key. When I pressed the start button with the new key nothing happened and I thought something was wrong. Then after about 2 seconds the locks cycled and the hazards blinked.
