Nhorn1983
About Nhorn1983
Nhorn1983's Achievements
  1. I tried searching and not finding a whole lot. What are you guys using for blow off valves on the 2.7l? not really seeing much out there .
  2. Dave, Did your come with the clear cover on it? Mine did not. I like the looks and functionality aspect of it. Thanks
  3. MY 21 ST also calls for ULV Fluid. The ST and non ST transmissions are the same except for gearing. I would strongly suggest not using anything other than Ford or Valvoline ULV fluid in your Edge.
  4. I think you are right. What was easiest for me was searching for a same year edge st, Checking the build date and if it was close to mine and within the part number dates ordering that part number that the researched Edge had. There is one Ford parts site that if you input the VIN it will give you the modules and parts that build has.
  5. I researched and for my build date i went with ML3Z-15607-K. I also ordered an Oem ST 5 button fob. I programmed the new fob as I had 2 keys already. Plugged the RTM in and instantly had remote start with absolutely no issues so far. Because of the research TPMS instantly worked with no issues to. I had to order another 5 button remote today also as the only thing the 4 button are good for now is starting the car from the emergency slot.
  6. Let me know how it goes and what the extra things you get are size wise for sure. Any chance you could upload a pic or two of the brace you received? Thanks
  7. I did some searching and have been unable to find anything. Does anyone have a strut tower brace on there 2021 ST?, or does anyone have a link or know where to get one? Thanks in advance
  8. Has anyone done this on a 21 ST? I put the part numbers from the first post but they say they don't work with a 21 ST. I would like to do this. Just want to make sure i get the right parts and that it is still in the same location.
