Rear view camera guidelines are missing
Wubster100 replied to ciggy's topic in Audio, Backup, Navigation & SYNC
FORScan is a free software. You only need to get a supported adapter for about $35 USD. -
Project - Get Active Cruise Control functioning
Wubster100 replied to andyh1108's topic in Accessories & Modifications
Adaptive cruise control down to 0 km/h and lane centering will not be possible without replacing many parts. It will be expensive and complex. It has been done on a Fusion before by replacing PSCM, SCCM, GWM, IPMA, CCM, all from a 2020 Edge. -
Can you provide more information such as the vehicle year/trim level/region? -
Questions, Comments & Complaints on 2020 Edge.
Wubster100 replied to JohnRR's topic in 2019-Current Edge & Nautilius
Failure Modes When a DTC is present in the PSCM, the EPAS enters 1 of 2 modes of operation. The EPAS system enters a reduced steering assist mode to protect the internal components of the EPAS system when a concern is detected by the PSCM such as low or high battery voltage or over-temperature concerns not considered to be a critical safety concern. This reduced steering assist mode gives the steering a heavier than normal feel. The EPAS system enters a manual steering mode (no electrical steering assistance is provided) when a concern considered to be a critical safety concern is detected. In manual steering mode, the vehicle has mechanical steering operation only, which gives steering operation a heavy feel. There are 3 failure strategies used by the PSCM for determining failure modes. The first strategy is limp home; when the PSCM detects a fault requiring the EPAS to switch to a failure mode, the PSCM calculates a "safe" level of torque assist and provides this assist until the ignition is cycled. If the fault remains during the next ignition cycle, the PSCM switches to manual steering mode until the fault is repaired. If the fault is not present during the next ignition cycle, the PSCM resumes normal operation and steering assist. The next strategy is limp aside; similar to the limp home strategy except the limp aside strategy can recover normal steering assist during the same ignition cycle if the fault is no longer present or the ignition is cycled. If the fault is still present, the PSCM switches to manual steering mode until the fault is repaired. The last strategy is ramp down; the PSCM uses all the various inputs to calculate a torque output command to provide steering assist, if the module cannot calculate this output, it uses the last known good torque command to provide steering assist until the PSCM completely removes assist and switches to manual steering mode until the fault is repaired. -
Finally finished installing ambient lighting in my 2021 Edge. The cup holders are OEM and everything else is aftermarket. The cup holders are only ice blue, and they are controlled by the SYNC screen. In each door, I installed a light in the door handle, door storage, and an LED strip along the door trim. I also installed 4 LED lights under the seats to light up the footwell areas. I also installed an LED strip above the glove box. All of the aftermarket lights are controlled by a hidden physical switch or with Bluetooth from my phone. I was able to get the cup holders for free by using Fordpass Points, and the aftermarket lights were only $34 USD (including shipping) for everything. Overall I am happy with the new ambiance.
Ford Edge Forum: WHAT HAPPENED?
Wubster100 replied to robertlane's topic in Forum Help & Site Suggestions
I hate the time out when searching for stuff in the forum. Why do I have to wait if I want to make a new search immediately following a previous search? It must be to prevent spam requests or something. -
Haz is the best! -
At night, I can see a slight red reflection when I look back. Too bad we don’t have any drive modes like an eco mode.
Heated Mirror Question
Wubster100 replied to BMWR1200c's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
The options that you see in FORScan are not always 100% reliable and correct. There may be differences due to vehicle model, firmware revision, region, etc. -
Both adaptive cruise control and normal cruise control will apply the brakes to slow down when your vehicle's speed is above the set cruise speed. This could hurt fuel economy when coasting down a hill. In theory, you should be able to achieve the best fuel economy by driving manually instead of using cruise control.
2020 Ford Edge RDU Fluid Replacement Observations
Wubster100 replied to MLLI18's topic in 2019-Current Edge & Nautilius
Thanks for sharing. I would like to replace my fluid soon. -
I probably won’t take the vehicle to a shop, just to save on labor cost. But I could try drain and fill 3 times, which should replace most of the fluid. And I can also try resetting the adaptive learning tables.
@BMWR1200cHere are the diagrams for the tail lights.Reversing Lamp - LH, Low Series Design - Connector C451 Details - 2020 Edge.pdf Rear Lamps - Wiring Diagram - 2020 Edge.pdf Reversing Lamp - RH, Low Series Design - Connector C461 Details - 2020 Edge.pdf Reversing Lamps - Wiring Diagram - 2020 Edge.pdf Rear Lamp Assy with Reversing Lamp - LH, High Series Design - Connector C4483 Details - 2020 Edge.pdf Reversing Lamp - LH, Low Series Design - Connector C451 Location - 2020 Edge.pdf Rear Lamp Assy with Reversing Lamp - RH, High Series Design - Connector C4484 Details - 2020 Edge.pdf Rear Lamp Assy with Reversing Lamp - LH, High Series Design - Connector C4483 Location - 2020 Edge.pdf Reversing Lamp - RH, Low Series Design - Connector C461 Location - 2020 Edge.pdf
My 2021 SEL has just about 70k miles and every once in a while there is a little bit of a harsh shift. I have only drained and filled the transmission once. I don’t think it made a big difference. I’m not expecting super smooth shifts each time, but I guess I will just have to keep doing drain and fills. I really hope that this transmission will make it to 200k miles and I would be happy.
New to the Forum, the Ford Edge and Canada
Wubster100 replied to Jay From SA's topic in Welcome Forum!
Hello from Pennsylvania -
I have an SEL and I have thought about upgrading my tail lights. The problem is that the cost of parts are too high. I am seeing about $200 to $300 USD for one tail light, and all 4 tail lights would need to be replaced to complete the full upgrade. Almost $1,000 USD for 4 used tail lights. But in terms of wiring and programming the lights, that is definitely doable. What I really want to see is someone try to fit the 2015-2018 tail lights into a 2019-2024. I think it would be nice to have a line of red leds across the back.
Welcome to the forums @BamaInArk Attached you will find a Youtube video and other information on removing the front bumper to access the fog lights. https://youtu.be/4ZjwjQ5wTEE?si=s8BYQ6mhI80Soz6- https://www.fordedgeforum.com/topic/33062-general-service-bulletin-24-7068-various-vehicles-exterior-lighting-concern-analysis/ BODY CONTROL MODULE (BCM) - Connector C2280B Details - 2019 Edge.pdf FOG LAMP, LEFT FRONT - Connector C152 Details - 2019 Edge.pdf FOG LAMP, RIGHT FRONT - Connector C162 Details - 2019 Edge.pdf Fog Lamps - Diagnosis and Testing - 2019 Edge Workshop Manual.pdf Fog Lamps Power Circuit - Pins 15 (LH) & 16 (RH) of Inline Connector C140 - 2019 Edge.pdf Fog Lamps Wiring Diagram -2019 Edge.pdf Front Bumper Cover - Disassembly and Assembly - 2019 Edge Workshop Manual.pdf Front End Ground Circuits, Including Fog Lamps Ground - Wiring Diagram - 2019 Edge.pdf Front Bumper Cover - Removal and Installation - 2019 Edge Workshop Manual.pdf
I wonder if the GM 9T50 gets the same complaints from: 2020– Cadillac XT6 (2.0 T LSY, 3.6 L LGX) 2019– Chevrolet Blazer (2.5 L LCV)[11] 2017– Chevrolet Malibu (2.0 T LTG) 2020– GMC Acadia (2.5 L LCV)[10]
Text sourced from @Haz Field Effect Transistor (FET) Protection The BCM utilizes an Field Effect Transistor (FET) protective circuit strategy for many of its outputs, for example, lamp output circuits. Output loads (current level) are monitored for excessive current (typically short circuits) and are shut down (turns off the voltage or ground provided by the module) when a fault event is detected. A Field Effect Transistor (FET) is a type of transistor that the control module software uses to control and monitor current flow on module outputs. The Field Effect Transistor (FET) protection strategy prevents module damage in the event of excessive current flow. Output loads (current level) are monitored for excessive current draw (typically short circuits). When a fault event is detected the Field Effect Transistor (FET) turns off and a short circuit DTC sets. The module resets the Field Effect Transistor (FET) protection and allows the circuit to function when the fault is corrected or the ignition state is cycled off and then back on. When the excessive circuit load occurs often enough, the module shuts down the output until a repair procedure is carried out. Each Field Effect Transistor (FET) protected circuit has three predefined levels of short circuit tolerance based on a module lifetime level of fault events based upon the durability of the Field Effect Transistor (FET). If the total tolerance level is determined to be 600 fault events, the three predefined levels would be 200, 400 and 600 fault events. When each level is reached, the DTC associated with the short circuit sets along with DTC U1000:00. These Diagnostic Trouble Codes (DTCs) can be cleared using the module on-demand self-test, then theClear DTC operation on the scan tool (if the on-demand test shows the fault corrected). The module never resets the fault event counter to zero and continues to advance the fault event counter as short circuit fault events occur. If the number of short circuit fault events reach the third level, then Diagnostic Trouble Codes (DTCs) U1000:00 and U3000:49 set along with the associated short circuit DTC . DTC U3000:49 cannot be cleared and the module must be replaced after the repair.
- 10 replies
- parking lights
- brake light
(and 2 more)
