Seat Heater Control Module GU5Z14C724A Edge 2016-2018 Seat Memory Control Module Unit GU5Z14C708BP Edge 2019-2024
Attention - there's an uptick in accounts being hacked
Wubster100 replied to 1004ron's topic in Forum Help & Site Suggestions
It doesn't look like there are any 2 factor authentication methods available either. -
What are the part numbers for all of the parking sensors retainers? They look similar to the image below, and the plastic retainer gets “welded” to the plastic panels of the car.
Group 65 Battery in 2nd Gen Possible?
Wubster100 replied to omar302's topic in 2015+ Edge & MKX Generation II
If you did not upgrade to a larger battery size or different battery chemistry, then there are no changes to be made except for resetting the BMS. -
Does anyone have any tips on how to ensure the vehicle is level while the front wheel is removed? I can park on a level garage floor.
2022 Edge ST rear fog light
Wubster100 replied to WilkiST's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
@WilkiSTNow that you are importing your vehicle from the US to another country, have you considered enabling the emergency flashing brake lights? This feature is common in Europe now. -
I currently have the original H6 AGM battery. A few months ago, auto start stop worked for a few days after I drove for about 8 hours on the highway. -
The last time I got my battery tested at a parts store, the tester said the battery was good, but it just needed charged. I will go to another parts store and get the battery tested. But isn't the battery supposed to be fully charged before testing? -
I went for a 30 minute city drive and the battery SOC increased from 34% to 39%. Once I parked I almost immediately lost Fordpass. The vehicle has about 70k miles, and I got it used, so I don’t know what happened in the past. I did use it to jump start a vehicle once. -
I think I will have to go with an H7 battery. My current battery is about 3 years old. The auto start stop hasn’t worked for about 10 months. The radio doesn’t stay on after the engine turns off. I always get the system off to save power message. When I start the car I have to wait a little while for the screen to turn on. Fordpass only stays connected for about an hour. The keyless entry stopped working. The biggest problem is not being able to use Fordpass to remote start, because it’s getting cold out. -
@onyxbflyDo you have any photos of the H7 battery installed? -
Is H7 the maximum size that will fit or has anyone tried to install a H8 battery? -
For 2019-2020 Edge, you must disconnect the brake lines and replace the entire abs module. Then you need to enter your VIN number and complete the ABS calibration. This can all be done using FORScan. Stop and go, lane centering, and evasive steering assist all work. For 2021-2024 Edge, more information is still needed because PATS immobilizer could be part of the ABS module. FORScan does not currently support ABS service functions or PATS service functions for 2021-2024 Edge. I am going to order an ABS module for my 2021.
Factory Install or UHaul?
Wubster100 replied to Samiii's topic in Cargo, Hauling, Roof Racks & Towing
The factory tow package includes a trailer tow module for trailer sway control. -
2022 Edge panic stops and turns hard left.
Wubster100 replied to Renegadebuck's topic in Owner Impressions
I have heard from someone that tested evasive steering assist. They claim that it felt like the vehicle basically switched lanes by itself after pushing the steering wheel over to the left. -
Are there any aftermarket audio accessories or other modifications? If pre collision assist was activated, then the IPC should have given a warning, and the ACM should have temporarily muted the radio. -
Is there also evasive steering assist? -
HOW TO add OEM Remote Start (2015+)
Wubster100 replied to colinc755's topic in Accessories & Modifications
[content deleted]- 45 replies
- guide
- remote start
Is your adaptive cruise control working? -
It seems like automatic emergency brakes were applied, and the steering wheel got pushed to the left. Evasive steering assist applied additional steering torque to the left. -
The lights look very nice! Lots of detailed photos. Thanks for sharing. It doesn't look like these new lights are able to reflect light, so it doesn't seem legal. I wonder if the original reflectors are able to be modified to fit lights inside of them. It seems impossible to find used ST / Titanium lights without paying a high price. I would love to know if it is possible to physically fit the center tail light from a 2015-2018 Edge.
