Wubster100
    9
  1. Do you know what the head up display is? Red LEDs in the dash?
  2. Is there a https://parts.ford.com/ website, but for other regions?
  3. You will know if the sound is coming from the IPC or ACM based off of the chime. The chime will sound older or newer.
  4. Doesn’t this only apply to SYNC 3 and not SYNC 4?
  5. Welcome to the forum @xtraorange. Do you see a seat module underneath the seat?
  6. Ensure the app is updated to version 5.9.0 You can now add service history information to your account to keep all your maintenance records in one place. Theft alerts now include a map view, history, and alert preferences. With a Security Package subscription, you can remotely lock down eligible vehicles to stop them from starting without permission. We've added real-time updates to your vehicle data, giving you access to the most current location information.
  7. Ford cannot do any programming. You must program it yourself using FORScan. The face plate with the heated seats buttons may not even be required if you only want to control the heated seats through the touchscreen. The heated seats are controlled over the network, through the seat modules.
  8. If it were me, I would use a third party software, FORScan, to reprogram the ABS module.
  9. FJDS provides module reprogramming software that covers 1996 to select 2018 Ford, Lincoln and Mercury module reprogramming functions, plus complete dealership level diagnostic software for all 2018 to present Ford and Lincoln vehicles. FJDS is designed for use with J2534 compatible Vehicle Communications Interfaces (VCI) including Ford diagnostic hardware (VCM II, or VCMM). The FJDS software license includes time based access to the FJDS software, software updates and calibration files. The following vehicles are supported by FDRS 2018+ Expediion/Navigator 2018+ Ecosport 2019+ Ranger 2020+ Transit 2019+ Transit Connect 2020+ Explorer/Aviator 2020+ Super Duty 2020+ Escape/Corsair 2021+ F-150 2021+ Edge/Nautilus 2021+ Mach-E All other vehicles are supported by IDS/FJDS
  10. Welcome to the forum @kcrews10! It is possible to install a SYNC 3 system and heated seats. I would assume that you have the small 4.2" screen. However, it is not plug and play. Programming is required for both the radio upgrade and heated seats.
  11. Welcome to the forum @Mbry2024! I never bothered to get new clips, so the seat cushion is still a bit loose. Have you tried looking at your cushion locking tabs / clips? Do you still have a warranty left on your 2023?
  12. Has anyone tried the LV fluid instead of ULV?
  13. There is a trailer tow module for the trailer lights and trailer sway control.
  14. The photos in the video are AI generated. There will not be a 2025 Ford Edge. However, there is a different vehicle, the Ford Edge L, which is larger and avalible in China.
  15. Wow… looking at the 2010 AsBuilt data versus modern Fords, there is a lot more data!
  16. Now, someone please tell me if 2015-2018 tail lights will fit 2019-2024
  17. No, there is only 1 module for each seat. The part numbers are from two differing generations of the Edge. Gen 2 2015-2018, and Gen 2.5 2019-2024
