Windshield Replacement
Wubster100 replied to 1004ron's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Is it normal for the automatic wipers to wipe once on startup? -
2020 Power source for trailer light converter
Wubster100 replied to Got 2's topic in Interior, A.C., Heat, Interior Trim
The 12v accessory power / "cigarette lighter" might be nearby for power. -
2016 Ford Edge DTC C1001 Backup Camera
Wubster100 replied to rdavis006's topic in Audio, Backup, Navigation & SYNC
Parking Aid PAC DT.pdfThis document contains B115E. -
Do you have the front camera with split view, or just the rear camera only? -
Have you completed the LIN new module calibration? -
FordPass no longer updating location while moving
Wubster100 replied to dabangsta's topic in Audio, Backup, Navigation & SYNC
Yes, I have dark mode on my iPhone, but the FordPass app doesn't change. -
Retrofit 360 Camera Into Ford Edge
Wubster100 replied to Wubster100's topic in Accessories & Modifications
The IPMB I have also supports Pro Trailer Backup Assist, but that will be disabled. The only big difference I see between the Expedition and Nautilus is that the Expedition has a hardwired camera button directly to the IPMB. I don't think that will be a big issue, I will try to get the camera button to work over the network instead. -
I would have never been able to attempt this project or my other projects, such as the adaptive cruise control, front and side parking sensors, or ambient lighting, without @Haz and the Ford Edge Forum! -
Still waiting for dark mode on my iPhone. Other iPhones and Androids have dark mode but I don't. -
Ford Edge Forum: WHAT HAPPENED?
Wubster100 replied to robertlane's topic in Forum Help & Site Suggestions
Forum down today? -
GSB 23-7146 - Determining Latest SYNC 4 Software Level https://www.fordservicecontent.com/ford_content/pdf/tsb/SYNC4LatestLevelSummary.pdf https://www.fordedgeforum.com/topic/32165-gsb-23-7146-determining-latest-sync-4-software-level-new-downloadable-document-lists-the-latest-sync-4-versions-available-for-all-fordlincoln-models-by-model-year/
- 24 replies
- 2
2022 SEL Rear View Mirror Pinout
Wubster100 replied to DavidD's topic in Accessories & Modifications
The necessary diagrams are attached above as PDF files. -
People have taken power from the IPMA for stuff like dashcams. Image Processing Module A (IPMA) - Connector C9224 Pin-Circuit Details - 2019 Edge.pdf Image Processing Module A (IPMA) - Connector C9224 Location - 2019 Edge.pdf Image Processing Module A (IPMA) and Cruise Control Module (CCM) - Adaptive Cruise with Stop and Start - Wiring Diagram - 2019 Edge.pdf Image Processing Module A (IPMA) - Grounds - Wiring Diagram - 2019 Edge.pdf Image Processing Module A (IPMA) - Removal and Installation - 2019 Edge Workshop Manual.pdf Image Processing Module A (IPMA) - Module Communications - Wiring Diagram - 2019 Edge.pdf -
Welcome to the forum @DavidD Where did you get that connector from? Are you going to get power from the front camera (IPMA)? -
The Trailer Tow Module (TRM) is responsible for managing the trailer's lamps. The TRM determines if a trailer is present by the trailer tow connection (4 pin white, brown, yellow, and green trailer wires). If the TRM thinks that a lamp is connected, then driver assist features such as the rear parking sensors will get disabled, BLIS will get disabled, and trailer sway control will get enabled. Because your Edge is new, you may still have a warranty left on it. Trailer Lamps The TRM supplies voltage to the trailer tow stop/turn lamps when the vehicle stop or turn lamps are commanded on. The TRM supplies voltage to the trailer tow parking lamps when the vehicle parking are commanded on. Field Effect Transistor (FET) Protection The TRM utilizes a Field Effect Transistor (FET) protective circuit strategy for its lamp output circuits. Output loads (current level) are monitored for excessive current (typically short circuits) and are shut down (turns off the voltage or ground provided by the module) when a fault event is detected. A Field Effect Transistor (FET) is a type of transistor that the control module software uses to control and monitor current flow on module outputs. The Field Effect Transistor (FET) protection strategy prevents module damage in the event of excessive current flow. Output loads (current level) are monitored for excessive current draw (typically short circuits). When a fault event is detected the Field Effect Transistor (FET) turns off and a short circuit DTC sets. The module resets the Field Effect Transistor (FET) protection and allows the circuit to function when the fault is corrected or the ignition state is cycled off and then back on. When the excessive circuit load occurs often enough, the module shuts down the output until a repair procedure is carried out. Each Field Effect Transistor (FET) protected circuit has 3 predefined levels of short circuit tolerance based on a module lifetime level of fault events based upon the durability of the Field Effect Transistor (FET). When each level is reached, the DTC associated with the short circuit sets along with DTC U1000:00. These Diagnostic Trouble Codes (DTCs) can be cleared using the module on-demand self-test, then the Clear DTC operation on the scan tool (if the on-demand test shows the fault corrected). The module never resets the fault event counter to zero and continues to advance the fault event counter as short circuit fault events occur. If the number of short circuit fault events reach the third level, then Diagnostic Trouble Codes (DTCs) U1000:00 and U3000:49 set along with the associated short circuit DTC. DTC U3000:49 cannot be cleared and the module must be replaced after the repair
Power lift gate does not open all the way
Wubster100 replied to edgemaster's topic in Exterior & Body
The latest version of FORScan is 2.3.64 release, 2024-12-16. Or for FORScan Beta users, 2.4.16 beta, 2024-12-17. -
Should I Replace My Water Pump and Thermostat
Wubster100 replied to Perspective's topic in 2.0L EcoBoost
I do not see the water pump listed in the scheduled maintenance. -
Oh, the Power Liftgate Initialization was already posted above. -
I do not know exactly what the Explorer owner means by "initialized the tailgate". Maybe they were referring to Programmable Module Installation (PMI) or something else. I have attached 501-03 - Body Closures - General Procedures - Power Liftgate Initialization If the attached document does not help, you could also try "re-load" the AsBuilt data: 1. Go to configuration and programing 2. Select RGTM Module Configuration (AS BUILT FORMAT) 3. At the bottom of the screen, select "Save All" button. 4. Save the AsBuilt file. 5. At the bottom of the screen, select "Load All" button. 6. Choose the AsBuilt file that you saved in step 4. 7. At the bottom of the screen, select "Write All" button. 8. Reboot the RGTM. Power Liftgate Initialization.pdf -
When the battery is replaced, the BMS must be reset. To reset the BMS without using a diagnostic scan tool: 1. Make sure all windows & doors are closed. 2. Turn ignition switch to on (don't start car). Wait 10 seconds. 3. Flash high beams 5 times using the "flash to pass" stalk on the side of the steering wheel (on/off, on/off, on/off, on/off, on/off). 4. Press brake pedal 3 times in 10 seconds. 5. The battery light on instrument cluster will flash indicating the BMS has been reset. Battery Replacement If the vehicle battery is replaced, it is very important to perform the battery monitoring system reset using the diagnostic scan tool. If the battery monitoring system reset is not carried out, it holds the old battery parameters and time in service counter in memory. Additionally it tells the system the battery is in an aged state and may limit the Electrical Energy Management system functions. Battery State of Charge The Electrical Energy Management system monitors the battery current flow and voltage to determine the battery state of charge. During the drive cycle the Electrical Energy Management system software monitors the charge and discharge current and increases the state of charge during charging, and decreasing it during discharge. During rest periods (key off with no electrical loads) when the vehicle enters sleep mode, the battery voltage is sampled to calibrate the state of charge. The sensor automatically executes this calibration anytime the vehicle enters sleep mode and when the total vehicle current draw is below 300mA. It takes 4 to 6 hours in the sleep mode to calibrate the battery state of charge to high accuracy. If the system draw does not allow the battery state of charge calibration over the previous 7 to 10 days the state of charge quality factor changes to flag this and some Electrical Energy Management system functions, which rely on the accuracy of the battery state of charge, may be temporarily turned off until a calibration takes place. Battery Monitoring Sensor NOTICE: Unless the battery is being replaced, DO NOT reset the battery monitoring system using the diagnostic scan tool. This reset is reserved for new battery installation only. This reset will clear the learned battery data, the battery time in service, and will affect the aging algorithm parameters, which have been learned since the installation of the battery. The battery monitoring sensor is integrated with the negative battery terminal clamp and cable assembly, which provides a ground to the sensor. The battery monitoring sensor measures voltage, current, and temperature of the battery and uses these inputs to calculate the battery condition. The sensor transmits this information through the LIN circuit to the BCM. The battery monitoring sensor has a 2-pin connector providing battery voltage and LIN connections.
Cruise Control alarm bell 2024 Edge
Wubster100 replied to mooseboy's topic in Interior, A.C., Heat, Interior Trim
There are multiple driver assist features for the Edge. Adaptive cruise control is used on highways and it will automatically brake / keep a distance to the vehicle in front of you. Lane centering is only able to be activated in conjunction with adaptive cruise control. Lane centering keeps your vehicle in the center of the painted road lines. Lane keep assist is available anytime at speeds above ~35mph. If your vehicle gets close to the painted lane line, the steering wheel will be nudged in the opposite direction to help keep you inside your lane. The 2024 Edge Ownerâs Manual describes these driver assist features in detail: https://www.fordservicecontent.com/Ford_Content/Catalog/owner_information/2024_Ford_Edge_Owners_Manual_version_1_om_EN-US.pdf -
@Haz, Do any Ford Edge workshop manuals or wiring resources mention anything else about a 360 camera system? I do not know of any Ford Edges that came with a 360 camera system.
