Wubster100
    26
3 Followers
About Wubster100
19,249 profile views
Wubster100's Achievements
  1. Don’t forget that the dynamic guidelines will not work right away. You must go for a short drive and rotate the steering wheel in all directions, then the dynamic guidelines will automatically calibrate itself and begin working.
  2. Are you replacing the CCM? Why not just copy all AsBuilt data from old to new. Then calibrate the CCM.
  3. It can be done but the difficult part is sanding / polishing the black frit away. https://www.team-bhp.com/news/diy-how-i-retrofitted-adas-my-ford-ecosport Or else mount it on the side. https://bronco6g.com/forum/threads/done-rain-sensing-wipers-installed.84493/post-2099209
  4. Put the original SYNC 2 system back in place. If SYNC 2 works normally, the wiring, ACM, SCCM, FCIM, vehicle network, and basic power supply are proven still working. Start FORScan with a completely new vehicle profile. Let FORScan discover every module again with the SYNC 3 assembly installed. Replace or test the LVDS cable and screen first. You must use a SYNC 3 screen and SYNC 3 LVDS cable. Do not use random AsBuilt files. A 2017 Escape configuration is a different platform. A 2017 Edge uses a newer vehicle architecture than your 2013 Edge. Incorrect APIM AsBuilt can cause missing climate controls, wrong steering button behavior, cluster errors, and configuration DTCs. The SYNC 3 APIM configuration needs to represent a North American CGEA 1.2 vehicle and your actual Edge equipment. Do not change the BCM, SCCM and ACM to match donor vehicles. The USB update is not a useful test. If the APIM is not completing boot, inserting an update drive will not do anything. Use this database to help program the APIM to match your vehicle. https://cyanlabs.net/asbuilt-db/?filter=apim
  5. Start FORScan without selecting the saved profile and allow it to perform a completely new module scan. A saved profile can continue expecting the old module arrangement.
  6. 1. Can you do an APIM self test? 2. Are you able to see the part number, calibration level, strategy, calibration, total distance?
  7. I don’t think this is possible. Did the AsBuilt really change? Have you actually compared the hexadecimal values to confirm a change?
  8. I got power from the door modules in the front, and in the back, power from the windows.
