AntB
About AntB
AntB's Achievements
  1. Thanks a lot for all the tailgate wiring diagrams. Do you also have diagrams and details of the connectors located in the rear headliner? This is where I would like to get the reverse light signal. Generally, these will probably be C408 and/or C411 plugs. Am I right and do you have diagrams and locations for them?
  2. Hello, I managed to find the pins for the rear low beam, brake, left (C414) and right turn lights (C417). I still can't locate the reverse lights. I found a thread on the forum that showed such a plugin, but did not explain where it was located. Maybe it's connector C4352, but I don't know where it is located. Anyone have an idea (photo, wiring or plug diagrams)?
  3. Hi, Does anyone have wiring and plug diagrams for the rear lights (brake light, reverse light, left and right turn signals)?
  4. The problem was exactly the module number ML3Z-15607-K (designation on the part itself ML3T-15K619-JA). After replacing it, all problems disappeared. Thanks.
  5. Signature updated. The car is no longer under warranty. My Edge was imported to Europe from the USA, hence the problem with finding a specialist with appropriate information such as diagrams of modules and sensors. And in this topic I will let you know if the problem is the RTM in the headliner at the back of the car.
  6. No No No This should be the matching part: https://dealer.parts.ford.com/shop/en/us/electrical/control-modules/transceiver-keyless-entry-receiver-p-ml3z15607k I'll try to find it and check the RTM, thanks for your help.
  7. Hello everyone, this is my first post here and I have some problems ;). In my Ford Edge Sel 2022 2.0EB (US version) it does not detect the remote control and tire pressure sensors. The first problem is not related to the remote control itself (it has a good battery, it is encoded as an admin key). The remote control itself is recognized in the backup slot inside the center console, so I can drive. The second problem remains despite using the procedure with tpms activator. Perhaps both problems are related to one sensor: https://www.searchfordparts.com/oem-parts/ford-tire-pressure-monitoring-system-tpms-receiver-ml3z15607x?c=Zz1lbGVjdHJpY2FsJnM9a2V5bGVzcy1lbnRyeS1jb21wb25lbnRzJmw9MyZuPUFzc2VtYmxpZXMgUGFnZSZhPWZvcmQmbz1lZGdlJnk9MjAyMiZ0PXNlbCZlPTItMGwtbDQtZ2Fz Where to locate it - do you have any photos, diagrams and installation diagrams? Or maybe some other tips?
