Arya
    2
About Arya
Arya's Achievements
  1. So hey guys after a better inspection one of the injectors was clogged so changed that injector car runs better than ever
  2. 3500cc v6 2012 SEL i know i know it was. Behind the timing chain my bad.
  3. Dillar have you got any social media or WhatsApp so that i can send u some videos
  4. Ive only replaced the water pump and changed the plugs coil num 4 was not acting like the others so we’ve fixed it and now im looking into injectors from a simple waterpump change to headache
  5. Well hello there unfortunately i wasnt there when they changed it i only know that they only opened the upper part of the engine and the engine was still in the cat right after the waterpump change we changed the oil {Motor craft} we didnt use any off brand or cheap parts because we’ve had this car since 2012 and it only has like 80-90k miles. the car runs great while driving it pushes harder than ever but when its idling i dont feel like im in a ford edge i feel like im in a mustang with stage 3 camshaft i did all the basics like i said [sparkplugs,MAF sensor, vacuum leaks, valve cleaner] it just annoys me when i stop at a red light and the car becomes a dancer. any help would be appreciated
  6. Hey paul have you fixed your car idle problem of your ford edge?
    Read more
  7. Hello there so recently I’ve changed the waterpump on my car now the car has a very rough idle when the car is started the rpm is between 630-650 after a drive the Rpm goes to 580-640 the engine shakes like a dancer there was a broken screw and it was causing a big vacum leak so i fixed it still the car was having a rough idle and ive recently changed the engine mounts and the car doesnt give me any codes i did all the basics of changing the spark plugs cleaning the throtle body its been a headache for real has anyone had the same problem and if so has anyone figured out a way to fix it? ! Attention ! - STOP - This section is reserved for topics on how to use this site - DO NOT use this forum for Ford Edge discussions - Forum Help & Site Suggestions - Ford Edge Forum
