Ctakacs9
Everything posted by Ctakacs9
  1. I took it back to Discount Tire and they checked all 4 sensors and they were responding so he said it's not a sensor issue and likely a system issue.
  2. 2007 Edge with ~120k miles. A few months ago the TPMS sensor failure started showing up on the dash. We had the sensors tested and a couple of them weren't responding or had low batteries, so we had all 4 replaced (which involved getting them converted from the bands to valves at Discount Tire). We also got new tires. The TPMS failure light didn't come back on after that, but after a few hundred miles it came back on and now is consistently on. I've checked the tire pressure numerous times. Any advice?
  3. Do the 2007 SELs have an IAC valve?
  4. Did you ever figure out a solution for yours?
  5. Yes it also happens when power is on but engine is not running.
  6. 2007 Edge SEL Inside the dash specifically right behind the gauges I can hear a clicking/rattling and slight squealing noise. It is constant, not dependent on other things running i.e. a/c. Wondering if anyone has any thoughts or similar issue. We thought it might be the actuator but after opening up the bottom dash and looking at the actuator it wasn't moving with noise happening. It kinda sounds like a plastic gear that's slipping. 20240315_110935_1.mp4
  7. Awesome - thanks for the reply. Was it easy to replace?
  8. 2007 Edge SEL When I'm idling with the a/c on, the RPM occasionally dips down really low and will sometimes stall. It runs fine as long as I'm driving, it's only when the car is stopped. If it does stall, I can start it right back up. I cleaned the throttle body about a year ago (it wasn't even really dirty but I did it anyway) when I replaced the spark plugs. Any ideas on what could be causing the low idle/stall only with the ac?
